  New Posts New Posts RSS Feed - B&C 2000W 18" Driver
Ajay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajay Quote  Post ReplyReply Direct Link To This Post Topic: B&C 2000W 18" Driver
    Posted: 30 November 2004 at 11:47am
Hi - I'm looking at building 4 1850 horns using B&C 18" drivers - has anyone used them for these cabs and are there any pointers as to how to get the best out of them? They'll be used to fill out the bottom end for hard dance/hard house music, likely to be powered by C-Audio amps. Any help appreciated!!
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2004 at 12:04pm
Hi,
That driver would be more suited to the 186 horn, as it has a Qts of 0.31. For bass horns like the 1850, which have a small rear chamber, you need a driver with a Qts of around 0.20, otherwise the driver will tear apart under high power levels.
Do you already have the drivers? If not, its worth concidering the Void V18-1000 driver for the 1850 horns.
Jamie
Ajay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ajay Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2004 at 12:09pm
Cheers Jamie - not got the drivers yet so will look into the Void ones as well. If I do go for the B&C units, it'll be the 186 horns instead then!!
On a not entirely unrelated note, how well will a pair of stacks of  2 x 186 horns and 1 x MT1202's go?
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2004 at 12:51pm
Do you mean the MT102 or MT122? I assume you are looking to build the MT122, in which case, have a look at these http://www.proaudioparts.co.uk/index.php?id=pornhorn
