  New Posts New Posts RSS Feed - B&C 21SW152 and 21DS115 long term power handling
 Post Reply Post Reply Page  <1 234
gen0me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gen0me Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 5:55pm
Strange that you dont heat them long term. You could measure impedance before and during/just after the test and outside temperature.
Ricci View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricci Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 6:21pm
Originally posted by Crashpc Crashpc wrote:
Wow, that is really brutal! In light of knowing that thermal capacity of the coil usually only allows for precious SECONDS of overloading before it burns in hell, and in light of knowledge that you do some "few period sweeps", I thought we´re talking roughly about 4-8 seconds of torture.
This one is not just mind blowing, but coil blowing, and the speaker still holds its own. Bravo! for B&C speakers! And thank you for very good and high strain tests, risking your own money for all of us. :-)
It is very demanding. The reason it is done like this is an effort to produce an accelerated heat buildup. I don't have time or the area for a whole other setup for much longer thermal compression testing over many hours with pink noise. This type of thing is already done with AES testing anyway. Also it will change drastically depending on the enclosure used and signal applied. This type is more abusive over the short term but not as abusive as applying a sine wave at a worst case frequency. At tuning for a vented cab for instance. Most drivers seem to bounce back from being driven to 3-4dB of thermal compression once or twice. I'm not sure that would be the case if heated that much many times. Of course I've burnt up some drivers and also broken some mechanically with this type of test. Using that type of signal also pushes the speaker extremely hard at all of its weak points in the sub bandwidth so it reveals a lot of warts, distortion and other bad distortions or sonic issues. Often driver excursion becomes a limiting factor right at about the time the driver is running into serious thermal issues. Whichever one throws up a flag becomes the limit for that test type.
logsquared1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote logsquared1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2017 at 9:04pm
Originally posted by ReubGold ReubGold wrote:
Any thing that involves bridging 9001, should really ring alarm bells.
Don't be scaredLOL  Pedal to the metalBig smile
Seriously though,  If your not putting at least 4Kw peak RMS to a 21SW152 you might as well get a cheaper woofer.
Crashpc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 6:19am
Well, if I rather listen to "square wave music", 2500 seems to be okay. :-D
Sirius Sounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sirius Sounds Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 10:59pm
What's 4kW peak rms? Is it peak or rms?! I was planning on putting about 2k7 rms and i think thats about 4k peak for my amp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote logsquared1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2017 at 11:55pm
The available wattage calculated from the maximum RMS voltage capability of the amplifier.   Roughly .707 X the Rail voltage.  Or the "continuous program" rating used by most woofer manufacturers.
ReubGold View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ReubGold Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2017 at 11:12am
If you have sufficient mains supply, would think 2x 4 ohm drivers per channel of 9001, each cab with it's own pair of 4mm2 conductors, should do the job, for reasonably sensitive drivers.
If he turns me into a zombie, first person I'm coming after is you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2019 at 1:34pm
Hey. Digging old corpses I guess...
In B&C, they say they put more wire into the magnetic gap with 21DS115, for motor strength. I still cannot wrap my head around how they did it. The math doesn´t work here (Resistance, wire diameter and length) for me. Looks like it is not possible with Aluminium. Yet they did it somehow.
That is not the topic though.
The more I think about it, the more it seems to me that the Al coil must be beefy one. Significantly greater wire diameter and volume than with Copper. And thicker coil body too, obviously. That might mean good things for cooling capabilities, couldn´t it? Greater coil area and volume/heat capacity. And the weight is also there. Mms of 21DS115 is greater than with 21SW115.
The 21SW152 doesn´t have much more coil area than 21DS115, and that is not counting for split coil of 21SW152. It might be, that the coil area of 21DS115 is the same as 21SW152, despite significant difference in the coil diameter. That would certainly make Ricci´s tests slightly less "unbelievable".
Andry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andry Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2025 at 5:46pm
I know it's an old topic, I just want to add the info on 21DS115 coil :
One way that the 21DS115 differs slightly from the previously released B&C 21's is that its 4.5 inch diameter voice coil is a thicker, 4 layer aluminum wind. This allowed the engineers at B&C to get similar motor force to that achieved using a much larger 6” diameter voice coil due to the extra winding layers. A 4 layer coil is heavier and typically has higher inductance but if it allows a smaller diameter, this can offer some advantages. A smaller diameter former is lighter and if using an internal magnet setup can also result in a smaller and lighter motor structure, with less magnet material needed. Also the smaller diameter former takes up less real estate on the spiders so a smaller diameter spider might be used or more corrugations could be left in the spider that might provide better linearity. The spiders used on the 21DS115 driver are a smaller diameter than those used on the larger 6” voice coil 21’s in the B&C lineup but since the former is 1.5” smaller in diameter this should offset the loss in overall diameter. The downside is that a thicker coil with more winds results in more inductance in general.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Crashpc Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2025 at 6:11am
Yes, I am aware. The totality of things might add up. Though understand that thicker wire and more layers on the coil means bigger gap and loss of flux. So doubling the wire doesn't mean double Bl just like that. But obviously, here we are, 21DS115 happened, it works.
In time, these drivers BOTH rose and dropped in my evaluations. In my usage, it is not enough coil, and 2000+ model is very needed, in order to work its purpose. On the other hand, for peaks, with these kinds of Bl, in 21" size it starts to show "that scary" bass, and it is able to blur my vision when I turn my back to it. So it is not that bad.
In the meantime,many thongs moved and changed. I have tested many more speakers, Celestion TSQ2460 arrived yesterday, and soon I am deploying a review platform.
