  New Posts New Posts RSS Feed - B&C 8PE21 horn
B&C 8PE21 horn
 Post Reply Post Reply Page  <1 234
doller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doller Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2019 at 3:55am
I think the OP used one.
And this is a really nice build loving the chunky look and the sp terminals. Very impressive.
Edited by doller - 28 January 2019 at 3:56am
luthier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2019 at 2:03am
Originally posted by doller doller wrote:
It's near impossible with a hand circular saw. They only bevel one way and it's always the wrong way. Cutting perfect matching panels near impossible. I am sure a few can do it.
The best way is to make an angled cut off jig for the table saw. You can get exactly matching panels. But yes it does always take a bit of trial and error.
With a circular saw yes, difficult and not very repeatable. However I would choose a good track saw like the TS55 or Mafell equivalent over all simarly priced table saws I have come across.
I can get the same accuracy and just as clean a cut with my TS55 as I used to on a Altendorf panel saw. It does take a bit longer to setup and I sometimes need to make a jig or two but it is an incredibly versatile tool that I use daily.
Also as a side note, it's not difficult to cut past 47 degrees with the right setup, whichever side of the blade.
catalin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 5:17pm
Finaly paint is done!!Smile
concept-10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concept-10 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 6:17pm
stunning Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2019 at 8:51am
Almost finish!
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2019 at 10:16am
no damping added? Try to get hold of some ‘twaron’
Post Options Post Options   Thanks (0) Thanks(0)   Quote catalin Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2019 at 6:21am
I will ad some,and do some measurements with and without damping.
JonB67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonB67 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2019 at 7:42am
Awesome looking job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote luthier Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2020 at 11:01pm
Love it, they look great.
