B&C DCX464 Coaxial Ring Radiator |
Post Reply | Page 12> |
4AC
Young Croc Joined: 18 September 2010 Location: Netherlands Status: Offline Points: 521 |
Posted: 19 March 2019 at 2:00pm |
So this appeared on my Facebook feed:
I am very curious to see what B&C will come up with. They have some catching up to do. Is there someone that already can tell a little more about these? Cheers
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
toastyghost
JBL and Eminence have ring radiators too now. The BLS patent expired.
MarjanM
BMS need to come out with something new now :)
Exciting times.
ErnieM
New Member Joined: 21 March 2019 Location: Fresno, CA Status: Offline Points: 1 |
65mm HF voicecoil
100mm for the MF |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1092 |
Hopefully I'm at please this year and check them out
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
DCX464 data sheet PDF?????
ceharden
Had a play with one today. Very smooth sound. Maybe too smooth for Rock'n'Roll but I'm sure some people will like it.
4AC
Seems like FBT is using this driver in their new MYRA 214L line array cabinet.
Oh and I saw this pic on a FB-page called Swampsound: |
snowflake
Old Croc Joined: 29 December 2004 Location: Bristol Status: Online Points: 3122 |
there's no way to put all that power at through that size throat over that bandwidth without it distorting.
toastyghost
Can say the same about BMS too. There are plots available for those who ask and you can bet it’s on the VoiceCoil / AudioXpress review list |
snowflake
I would say the same about BMS drivers. reviews typically measure distortion at 2.83V. increase the power by 20dB and you will get a very different distortion plot and realise that at high powers it is throat geometry that dominates distortion, not how expensive your comression driver is. EDIT: to be fair, throat distortion is mainly second harmonic and less objectionable than higher order harmonics and inter-modulation distortion produced by compression drivers. second order harmonic distortion is so normal that people perceive that as what loud noises should sound like.
Edited by snowflake - 18 July 2019 at 5:30pm |
fatfreddiescat
I think you may be right there: |
