B&C DE250 vs new DE360? |
Post Reply | Page 12> |
BatteryLow
Registered User Joined: 14 January 2023 Status: Offline Points: 17 |
Posted: 23 January 2023 at 7:22pm |
https://static.sonovente.com/pdf/technical/8/8907_de250_8.pdf https://static.sonovente.com/pdf/technical/72/72922_de360_8.pdf The DE360 is rated 110db and 35W RMS The DE250 is rated 108.5db and 60W RMS The DE360 claims new diaphragm technology with HT polymer, plus has neodimium People here swear by the DE250, I have bought two but considering changing them to DE360 as I can buy them for the same price I'm a noob. 1- I want to pair 2 of these with 2x 10" 300w and 1x 15" 400w, both serve me? 2- Which one can go louder? 3- Which one should sound better? I understand the DE360 cause new tech why not 4- Does neodimium offer another advantage apart from weight? Thank you guys! |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Sorry for edit: 1) should work well with 10" direct radiator 2) de250 can take 2,3 dB more max. Power, but de360 is 1,5 dB more sensitive, so the overall max output difference is 0,8 dB so about the same. De250 max spl 129,29 De360 max spl 128,45 De250 goes in theory 0,8(edit) dB louder, and takes more spanking because of slightly larger voice coil, but also rolls steeply off beyond 16 kHz (most people won't notice). De360 has no peaks or severe roll off all the way up to 20 kHz. But it has a gentle roll off above 10 kHz, about 5 dB, but thats ok. If you don't intend to spank your speaker too much, and are curious about better quality i'd try the de360. Should sound a little bit smoother, even if you can't hear the rolloff of the de250. In theory, the de250 coil might thermally tolerate a small margin of extra abuse. Oh, and you have to cross the de360 a little bit higher than the de250 Edited by bob4 - 24 January 2023 at 5:18am |
BatteryLow
Thanks for the answer. I should read aboth dB, being a beginner it's what I should started reading xD I mean you say max output differend is 0.8db but de250 goes 1,5 louder? Do you mean at max RMS each?
bob4
Yes, I meant at max rms, but the 1,5 was a rough guesstimate, doing the actual math the difference was only 0,8 dB. If the program power rating of the de360 was 10 w less (60w), the difference would be 1,5 dB. Check sengpielaudio for dB calculators and general information about (electro)acoustics and the associated maths The difference in outcome (max spl output) is negligeable. You won't notice it. Its more likely there will be differences in subjective perception of the sound, due to differences in distortion, and the different frequency responses.
Edited by bob4 - 24 January 2023 at 5:25am |
Besa
Registered User Joined: 04 June 2018 Location: Italy Status: Offline Points: 49 |
I think the de360 will worth a try because I work in a club in wich are installed 4 bins of 2-way speaker at the corners of the rooftop and I don’t like the sound of the de250 at club-level volume.
De250 may sound OK at lower volume but when you feed them with power it starts to sound harsh with lot of distortion
levyte357-
Very suprised to hear 1" being used in a club, as main Compression driver. I would have specified nice sounding 2", for 1.8khz to 11hkz, then 1" for 9khz and above. Also, correct horn selection for compression drivers, is absolutely vital.
cravings
what frequency are the de250s covering, and what else is in the box with them?
kipman725
Registered User Joined: 02 September 2020 Location: Warrington Status: Offline Points: 231 |
Polymer diaphragms will soften when run at high power, generally recommended to use metal diaphragm drivers for sustained high power use. However polymer diaphragms are usually less resonant and smoother sounding for lower power use (hence the popularity of the DE250 for Hi-Fi). the DE360 is an annular ring diaphragm driver giving it excellent HF sensitivity and extension: Annular rings have a very different phase plug design to dome drivers so are not excursion limited by the phase plug distance from the diaphragm but by the diaphragms 'suspension' (often the diaphragm itself) or the magnet structure. whereas the DE250 uses a dome diaphragm: this has a greater surface area and therefore allows the driver to be crossed lower and as the voice coil is larger also handle a bit more power. However the HF efficiency isn't as high and the driver rolls off earlier. This earlier roll off is probably a compromise to increase the driver phase plug gap enough to have a low crossover point. The gap is required for diaphragm excursion but also forms a low pass filter. |
Besa
They are in HKaudio IL15.1 speakers, they cover 2kHz - 20kHz I don’t know if the horn is the best choice.
BatteryLow
Thanks for the answer guys, anyways I keep being not sure about the change or not Maybe I'll stick to the DE250 just because everybody knows it
levyte357-
You won't hear much abve 16khz, if you are running them below 3khz.. Best horn I have heard them on, is the B&C alum ME45.
BatteryLow
https://static.sonovente.com/pdf/technical/28/28717_h1-9040p.pdf I bought this one for the DE250, they say in here it's a very good cheap one, my intention is to make a mold of it and make it cast aluminium xD Soooooo keep the DE250 guys?
