  New Posts New Posts RSS Feed - B&C MH32 v B&C 12NDL76
mrspock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock Quote  Post ReplyReply Direct Link To This Post Topic: B&C MH32 v B&C 12NDL76
    Posted: 24 April 2007 at 6:58pm
Hi has anyone ever used B&C 12NDL76 as ide like to now what it sounds like.  Has it more bass responce than the MH32 driver or sound as nice.
Cheers Chris
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2007 at 3:13am
We use the 12NDL all the time. It is a great speaker. We use it as a bass/mid in 2 way speaker cabs. The only way to choose on the day is to AB them. The overall response will be determined by the crossover. Neos do seem to be more effecient in the mid band compared to their standard counterpart.
Edited by TONY.A.S.S. - 25 April 2007 at 3:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrspock Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2007 at 5:23am
Hi what's AB?  and what cabs do you use and what bass responce  can you get.
Cheers Chris
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2007 at 9:41am
How many times have I posted about the 12NDL76?!?
Same as Tony, it's a great driver.
Have also done an AB with the 12MH32 and apart from the weight they are practically identical.  Sound equally good.  TS parameters are almost the same too.
Neither speaker does bass, they're upper bass/midrange drivers and very good at it. You can force the NDL76 to produce more bass (using EQ) because it has greater excursion capability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 25 April 2007 at 11:41am
Cheers Chris
AB.= Compare one with the other best done with a switch over box.
SWITCH OVER BOX = Makes AB testing easy.
