  New Posts New Posts RSS Feed - B&C Speakers with HD15
Aya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aya Quote  Post ReplyReply Direct Link To This Post Topic: B&C Speakers with HD15
    Posted: 17 February 2014 at 12:25pm
Hello,
I have some B&C 15PS100 drivers availables, and I'd like to know if they will be ok
for HD15 Horn project ?
Thanks !
janovic_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote janovic_x Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 8:58pm
2pi
black = PD154
grey = B&C 15PS100
Better is the B&C 15PL40, this works great!
geoSal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 17 February 2014 at 9:16pm
I've been using pl100 for 6 years now with very good results but never heard pd154.I ve also tried 15pzb100 which reached a lit lower on freq but i got more spl with same wattage with pl100 and more kicky sound
Aya View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aya Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2014 at 8:47am
Thanks for the replies..
My using of the 15PS100 will be for low bass spectre from 100 Hz to 250 Hz...
According to the SPL response, it seems not too bad ??
Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2014 at 12:45pm
using the hd15 from 100hz and up would be a waste of useful energy.This box can easily play from 75-80hz and give its max sensitivity in 100-110hz.unless you have just one or two boxes per side i wouldnt recommend tuning higher than 85hz and again with 12db slope.PS100 would be fine
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2014 at 10:40pm
it also  doesnt sound very good above 160/170ish hz
horn loaded for her pleasure
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2014 at 10:45pm
15PS100 is designed to be used in cabs going lower in frequency and probably not horn loaded.  Good for reflex and possibly 6th order bandpass.
The HD15 is a very specialist bass cabinet, only really works well for certain music styles.
