B&C Speakers with HD15 |
Aya ![]() Registered User ![]() Joined: 29 August 2008 Status: Offline Points: 68 |
![]() ![]() ![]() ![]() ![]() Posted: 17 February 2014 at 12:25pm |
Hello,
I have some B&C 15PS100 drivers availables, and I'd like to know if they will be ok for HD15 Horn project ? Thanks ! |
janovic_x ![]() Registered User ![]() ![]() Joined: 27 November 2012 Status: Offline Points: 80 |
![]() 2pi black = PD154 grey = B&C 15PS100 Better is the B&C 15PL40, this works great! |
geoSal ![]() Registered User ![]() ![]() Joined: 05 July 2011 Location: THESSALONIKI Status: Offline Points: 338 |
I've been using pl100 for 6 years now with very good results but never heard pd154.I ve also tried 15pzb100 which reached a lit lower on freq but i got more spl with same wattage with pl100 and more kicky sound
Thanks for the replies..
My using of the 15PS100 will be for low bass spectre from 100 Hz to 250 Hz... According to the SPL response, it seems not too bad ?? Thanks again |
using the hd15 from 100hz and up would be a waste of useful energy.This box can easily play from 75-80hz and give its max sensitivity in 100-110hz.unless you have just one or two boxes per side i wouldnt recommend tuning higher than 85hz and again with 12db slope.PS100 would be fine
Mark James ![]() Old Croc ![]() ![]() Joined: 15 January 2006 Location: rig side Status: Offline Points: 5299 |
it also doesnt sound very good above 160/170ish hz
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11682 |
15PS100 is designed to be used in cabs going lower in frequency and probably not horn loaded. Good for reflex and possibly 6th order bandpass.
The HD15 is a very specialist bass cabinet, only really works well for certain music styles. |
