  New Posts New Posts RSS Feed - B&C sub18 186/2 loaded hpf
dj jammin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Topic: B&C sub18 186/2 loaded hpf
    Posted: 03 November 2019 at 10:34am
I have recently acquired 4 sub18 cabs (old bc design ) loaded with pd 186/2 drivers..
Just wondered what peoples options on the ideal hpf for these ..
Im guessing something like 40hz 18dB
Is there a formula to calculate this? Also wondering about the pro's and cons of different slopes ie 12/18/24 dB per octave..  would 12dB slope provide enough protection?
Any thoughts on this will be much appreciated..
Reverence Sound system
www.mixcloud.com/B1_Jams/
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 03 November 2019 at 1:24pm
It's certainly something you can model in software such as WinISD, Hornresp or VituixCAD.
You can get enough protection from a shallower slope like 12dB, but you usually have to set the corner frequency higher to get it, which can eat into the response within the intended passband of the subwoofer. A steeper filter can be pushed to a lower frequency for a given degree of protection, potentially avoiding that problem.
However, steeper filters have more phase shift and thus group delay, so may be perceived as slower or less tight sounding.
One happy medium is to use the lower order filter with a little boost from a PEQ just at the box tuning frequency to restore the lost level there - that gets you all the in-band response with a little less group delay than the steeper filter.
The differences aren't huge to be fair, but they're interesting to be aware of anyway.
Here's a 186-2 in 172 litres tuned to 36Hz (approx what you'll have, depending on how much space is used up by handles, bracing etc) with a few filter options.
HTH,
David.
Edit to add: the yellow trace for the 12dB filter on its own has it's input signal turned up a bit to allow for the fact that the HPF has reduced excursion in-band as well as below box tuning frequency.
Edited by DMorison - 03 November 2019 at 1:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dj jammin Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2019 at 12:01am
Thanks very much for the reply David..  useful info
