  New Posts New Posts RSS Feed - Behringer 1800d transfer to 186 horn
mmitc62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmitc62 Quote  Post ReplyReply Direct Link To This Post Topic: Behringer 1800d transfer to 186 horn
    Posted: 27 June 2014 at 8:54am
I have a pair of behringer 1800d subs that id like to get a bit more efficiency out of.
plan is to use driver and amp from 1800d and make an active 186 horn.
Anyone see any problems with this idea?
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2014 at 10:08am
Well it might work, but you will never know unless you try it out as the t/s parameters are not available for that driver so you can't simulate it.
Could be a fun little project, and you can upgrade to a compatible driver down the line :)
wafflesomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wafflesomd Quote  Post ReplyReply Direct Link To This Post Posted: 27 June 2014 at 9:21pm
You could try a tapped horn.  Most drivers work pretty well in them.
Gonna be hard to know though unless you've got t/s parameters like patryk1305 said.  In my experience a lot of the behringer drivers seem to rebranded pyle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 01 July 2014 at 7:21pm
seems like a lot of effort for what will probably provide little to no improvement! Just cabs twice the size which don't drop so deep...
Radeon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Radeon Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2014 at 1:46pm
dont waste your time and money,behringer drivers are total sh**
and even if it would work "great"(it wont) ,186 doesn't go low as that berry reflex box,so you lose ...
plus that amp power is also questionable, better leave it the way it is  Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2014 at 2:15pm
He never said he wanted go low in the first place, he wants to gain efficiency.
