Behringer 1800d transfer to 186 horn |
mmitc62 ![]() New Member ![]() Joined: 25 March 2014 Location: Australia Status: Offline Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 27 June 2014 at 8:54am |
I have a pair of behringer 1800d subs that id like to get a bit more efficiency out of.
plan is to use driver and amp from 1800d and make an active 186 horn. Anyone see any problems with this idea? |
patryk1305 ![]() Registered User ![]() Joined: 13 December 2012 Location: United Kingdom Status: Offline Points: 488 |
Well it might work, but you will never know unless you try it out as the t/s parameters are not available for that driver so you can't simulate it.
Could be a fun little project, and you can upgrade to a compatible driver down the line :)
wafflesomd ![]() Young Croc ![]() Joined: 21 September 2007 Status: Offline Points: 811 |
You could try a tapped horn. Most drivers work pretty well in them.
Gonna be hard to know though unless you've got t/s parameters like patryk1305 said. In my experience a lot of the behringer drivers seem to rebranded pyle. |
mk2_ginger_biscuit69 ![]() Old Croc ![]() Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7801 |
seems like a lot of effort for what will probably provide little to no improvement! Just cabs twice the size which don't drop so deep...
Radeon ![]() Registered User ![]() Joined: 22 November 2011 Location: Croatia Status: Offline Points: 277 |
dont waste your time and money,behringer drivers are total sh**
and even if it would work "great"(it wont) ,186 doesn't go low as that berry reflex box,so you lose ... plus that amp power is also questionable, better leave it the way it is ![]() |
He never said he wanted go low in the first place, he wants to gain efficiency.
