  New Posts New Posts RSS Feed - Behringer ultradrive dcx496 update
Message Reverse Sort Order
soundsystemdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Topic: Behringer ultradrive dcx496 update
    Posted: 13 November 2006 at 4:50pm
yeah, still need to get hold of a 9 pin straight through cable, after finding one that wasn't wired straight through.
IIRC my version is 1.14, Strange Daze is 1.16.
Originally posted by Srange Daze Srange Daze wrote:
NO EGGS FRYING
well it is brand new, give it chance.
I'll stick a new plug on mine "eventually", mean time noise goes goes away after a few minutes warm up, either that or it is too quiet to notice once music is played at a moderate level.
james folkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote james folkes Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2006 at 11:24am
Originally posted by Strange Daze Strange Daze wrote:
AND SEEMS THEYVE BEEN UPDATED.....AFTER PLAYING ABOUT WITH MINE AND DANS A FEW GIGS AGO.....I FOUND MINE HAD 7% MORE PROCESSING LEFT THAN SOUNDSYSTEMDANS, AFTER APPLYING THE SAME EQs AND CROSSOVERS ETC.
sounds like dan's has still got version 1.2 of the firmware on it. download 1.3 from the berry site and upgrade over 9 pin serial cable using the dcx remote software. i love the way behringer claim that this new version of the software eliminates the dropping out between filter modes and delay points etc... my arse it does! but yeah, one thing it does do is make about 7% more processing power appear from nowhere.
james.
mardy hippy.
Strange Daze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2006 at 5:15am
IM ABSOLUTELLY BUZZING WTH MY NEW BERRY DRIVERACK.
f**kING GOOD JOB TOO.... NO EGGS FRYING..... MORE PROCESSING GRUNT...... IM CHUFFED.
Danmounter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danmounter Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2006 at 9:24am
In response to mashgwan
The only product I know behringer went to court over was their MX8000 desk, which bore an uncanny resemblance to the mackie 8 bus series! I think they settled out of court, and produced the MX9000 instead, which was still damn near the same by all accounts!
With regards to the DCX, mine has had it's ribbon cable replaced, and it had a cracked PCB which lowered the output of channel 6 by about 15dB on their scale. I had it fixed by one of the Allen &Heath service agents in Cheshire, which was annoying, but no frying egg problems so far (touch wood)
Has anbody else had an output go quiet on them?
Dan
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2006 at 1:05pm
Originally posted by soundsystemdan soundsystemdan wrote:
So you just replaced the plug on the end of cable, and left the connector on the pcb as it is.
Yes, you obviously have to take the connector apart to free the existing cable but thats it.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2006 at 6:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2006 at 5:57am
@ wilkee
Glad to hear it, how would you rate the soldering skills required, compared to something like soldering a balanced xlr?
No soldering skills required. Simply reuse the one header that is fixed to the PCB and replace the header fixed to the cable (I obtained my new ones from Maplins 13 pin DIL ).
To remake the connections in the IDC's I used a block of wood under the PCB and gently tapped the top of the connector untill the cable is fully seated.
For the cable I just cut some floppy drive cable to the required width (26 conductors) and length.
If a dumb bugger like me can do it it shows it must be simple.
Tony
p.s. The fact that just replacing the cable and not touching the soldered  headers is what makes me think that the problem has lain with the cable all along.
Edited by wilkee - 01 August 2006 at 6:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2006 at 2:25pm
@ wilkee
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2006 at 1:25pm
As this thread has been revived I am happy to report that the two Ultradrives on which I replaced the ribbon and headers have both been perfect since.
On one of the units it had previously refused to go more than about 2 weeks without either a channel cutting out or the "frying tonight" sign coming out.
Result!!
Tony
Edited by wilkee - 31 July 2006 at 1:26pm
Laurence G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laurence G Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2006 at 12:55pm
You need a PCMIA to Flash Convertor...
Luckily I had one lying around from an old palmtop we used to have. I think the DCX can only utilise 4mg of any memory card.
I've just had a DCX come, and it was apprently manufactured in April of this year. So we will see how it fars!
Shame it doesn't have a blue screen! >.<
Laurence
Post Options Post Options   Thanks (0) Thanks(0)   Quote soundsystemdan Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2006 at 12:12pm
now then,
I admit I'm hijaking this thread so all you who have already replied get an email, sneaky me.
I'm after a PCMCIA card for my ultradrive to store settings on. I've tried searching the 2 biggest PC bits shops in Manchester (Micro direct and Aria) only to find things that plug into PCMCIA but aren't memory things.
Can someone please point point me in the direction of what I'm looking for?
btw pleasure to meet you at Shamania James, ind.st. I am Dan who was helping out with the Strange Daze rig.
Dave Slater View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Slater Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2006 at 7:00am
Originally posted by mashgwan mashgwan wrote:
aren't behringer also being sued at the moment because the ultra drive is very similar to some one elses product, isn't that the reason why they aren't being sold at the moment
dunno about being sued for copyright
you can build something that looks like a competitors (how many cars look the same?) and just say that through your design process, form followed function and that was the result
as long as inside something is different, (a chip, a couple of resistors and a few changes to track layout etc) all's good
patents are a different matter entirely
they are having problems in the states at the moment however
http://srforums.prosoundweb.com/index.php/m/116072/0/?srch=b ehringer#msg_116040
as to their availability i was under the impression their factory was set up for batch runs of stuff one product after another
it may well be that as they've just released some new products it's be a while before the dcx hits the production line again
