Behringer Ultradrive Problems Poll |
Page <1 282930 |
ermannofusini
Joined: 18 November 2019 Location: Italy Status: Offline Points: 10 |
Posted: 24 November 2019 at 12:03am |
Agree
ermannofusini
Posted: 24 November 2019 at 12:04am |
Usb or thunderbolt?
stanley dj
Joined: 19 July 2013 Location: Ireland Status: Offline Points: 163 |
Posted: 27 December 2019 at 7:18pm |
Dcx 2496 and deq 2496 are good machines but soonest u get one replace all capacitors in power supply. And sometimes u need redone ribbon cable they are rubish other way is sound good compare to more expensive units I was using it for years this units is also use in high end systems with little modifications on preamps
APW
Joined: 13 November 2012 Location: UK Status: Offline Points: 1234 |
Posted: 04 March 2020 at 6:10pm |
If you have one of the older units with the card slot DO NOT use firmware versions newer than V1.16, it will brick your unit. Newer units have a slightly different hardware configuration and the newer firmware is for the later hardware. |
teeth
Posted: 17 October 2021 at 10:36am |
these get so much hate, but i really love mine. so useful and for the price, you can't beat it. i prefer the interface to something like an XCA to be honest.
1ManSoundsystem
Posted: 17 August 2022 at 3:53pm |
i have 3 2 LE (2 inputs) and 1 PRO (3 inputs) at LE: the selector wheel got very inaccurate meaning, that if you turn it (it has small grid/raster) and u jump over 4 or 5 teeth, the on-screen selection changes just 1 digit. the faster you turn the wheel the less values change. in the end, i had to turn the wheel VERY slow and smooth to hit the desired values. i sent it in for repair, ~80eur since then it works allright. at PRO: some fool vaporized input A by fiddling around with his medieval shit.... i was drunk like a skunk, so i didnt notice that he was plugging countless plugs and sockets for no reason ! at some point, input A was dead, we found out after 15min looking for errors....didnt got it repaired, cost be about 150, that too much, i got in B and C left, thats allright. whenever we do a gig, i have 1 spare dcx with me...............u just never know
![]() Edited by 1ManSoundsystem - 17 August 2022 at 3:54pm |
Tinnitus Rex
Joined: 31 October 2020 Status: Offline Points: 311 |
Posted: 17 August 2022 at 6:15pm |
Damaged inputs to audio equipment? Laptops and other switching power supplies can cause 120v (half the 240v UK)to go up the input of whatever supplies the best ground for it, ( you will notice this if you have any nasty back"ground" noises that have been talked about here at length) Always use an isolating transformer between "it" and your system, or/and measure the voltage difference,with a multimeter, between the source (pin 1 ground xlr,or jack sleave) and your pin 1 ground before connecting. Beware, If someone is hot connecting a jack, the tip touches ground before it reaches its connection and VERY loud clicks indicate a massive ground voltage difference occuring for that moment.
"couldn't we just like... use headphones?"
Page <1 282930 |
