Behringer Ultradrive Problems Poll |
Page <1 23456 30> |
Bespoke ![]() Old Croc ![]() Joined: 20 August 2007 Location: Gone Status: Offline Points: 1886 |
But what is it Norty ? what happens ?
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8802 |
If you imagine the sound of eggs frying, but coming from the outputs of the DCX, thats exactly what it is. Often if you wiggle the cables in the back or tap the case you'll get a really loud pop.
Normally only affects some of the outputs Edited by norty303 - 04 December 2008 at 10:43pm |
huw ![]() Registered User ![]() Joined: 23 September 2008 Location: Aberystwyth Status: Offline Points: 15 |
Mine sounded like blasts of machine-gun fire to me
and the other output was white noise if I recall correctly.... |
well on mine I only get the noise - no music signal whatsoever
Wrighty ![]() Old Croc ![]() Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
I've got one old and one new - both fine, although they don't get a lot of use.
ALL YOUR BASS ARE BELONG TO US.
WmAx ![]() Registered User ![]() Joined: 07 May 2008 Status: Offline Points: 8 |
I have two units, one purchased around 2005 and on purchased in 2007. Both have never had a fault.
-Chris |
Fushion Julz ![]() Registered User ![]() Joined: 19 August 2004 Status: Offline Points: 647 |
I have 2...one is a (very) early model and it suffered from a failure to boot on one occasion...Solved by reseating the ribbon cables and insulating the bottom of the case as a precaution.
The other is a later batch one and has suffered no issues whatsoever... Fantastic bits of kit, great value for money, too, IMHO |
adambomb ![]() Old Croc ![]() Joined: 10 April 2006 Location: United Kingdom Status: Offline Points: 3215 |
I have 2 units.. oneold, but not that old (about 2 years at a guess).. one new (last month)... no issues whatsover with either.
I have only ever used a DCX as my own crossover and have little experience with other brands etc.. but when I do come into contact with other stuff (Driverrack etc) I'm always shocked how inflexible they are compared to the DCX and also how awkward they are to use.. when the DCX is childs play in comparison.
Top marks from me..
Sound quality always seams to be good too..
Just wish the limiters went down another 3db or so... my only gripe.
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10705 |
Adambomb: Don't forget the familiarity factor when you deal with other bits of kit though. Those other interfaces will rub up against your expectation from what you're used to, and that will taint your experience somewhat.
I personally find the DCX interface to be good, but basic and not very well categorised, but I know that my regular usage of a DBX and it's clearly defined categories is a major factor in that. For someone who's coming into it with minimal experience or a wide breadth of experience (freelancing, for example) then I'd still wholeheartedly recommend the DCX even though it's not my cup of tea. |
I agree, to some degree familiarity does play a part... but a 2 char high display as found on most other LMSs is a lot harder to use by far.. much less graphical representation of what's going on.
I also agree on the catagorisation of some areas is a little whack... but again, from my experience a whole sh*t load more intuative than the DRPA etc.
If your experience of a DBX is the DRPA then fair enough. The multi-line display on the 260 and up is a godsend though.
Page <1 23456 30> |
