  New Posts New Posts RSS Feed - Behringer Ultradrive Problems Poll
 Post Reply Post Reply Page  <1 27282930>
Poll Question: I own/have owned a DCX2496 Ultradrive and it was....
Poll Choice Votes Poll Statistics
14 [4.46%]
11 [3.50%]
13 [4.14%]
184 [58.60%]
44 [14.01%]
48 [15.29%]
You can not vote in this poll
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2017 at 1:30am
But some of us don't have old hardware and have to use USB.....
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2017 at 4:33am
You can get a serial card for under a 10. Or I got a p4 desktop on free cycle the other year just for updating a few old omnidrives via serial.
msoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote msoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2017 at 8:52am
Il just buy a serial card as It can be handy for other things. Will get a card and update the dcx with the firmware, if it doesn't work or cure the fault I will swap the Eprom chip and try again. Will post update when tested. Many thanks!
Sam Daniel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam Daniel Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2017 at 3:09pm
Originally posted by msoundsystem msoundsystem wrote:
thanks for the reply! so i am going to replace the main EPROM chip. i have found an equivalent as the original one doesn't exist anymore. ( equivalent chip AM29F040B ) my question is do i need an EPROM burner to program it with the DCX Latest firmware? or can i install the chip in the DCX then connect the ultradrive up to pc and install firmware that way? if i need an EPROM burner can someone recommend me a budget one? most likely i will only use it a handful of times.
thanks again.
Dear msoundsystem,
You're very welcome for the reply. Typically, our in house repair technicians will use an EPROM burner. However, we do not have a specific recommendation for a burner to use.
Let’s keep in touch,
Sam Daniel
Specialist, Care
MUSIC
http://www.ebay.com/sch/Consumer-Electronics-/293/i.?_nkw=behringer - Behringer
Explicit 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Explicit 2 Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2017 at 6:23pm
Hello
I have a Behringer DCX2496 that I bought second hand, when I power it up after not using it for a while the LCD dsplay flashes for 1 to 3 minutes then it is ok and it works fine.
Is it faulty?
Is it going to die soon?
Thanks
'Whether you believe you can or you can't your right' Im here to learn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam Daniel Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2017 at 4:30pm
Originally posted by Explicit 2 Explicit 2 wrote:
Hello
Is it faulty?
Thanks
Dear Explicit 2,
Thanks for reaching out to us. The issue you are describing with your DCX2496 is definitely not an issue that we typically see with these units, and it could point towards a fault with the unit that may cause damage to the unit over time. Therefore, we would highly recommend having the unit looked over by a BEHRINGER authorized service center. For reference, the list of BEHRINGER authorized service centers can be accessed by selecting your country in the following link from the BEHRINGER website:
http://www.music-group.com/brand/behringer/store-finder?type=POS
I hope this helps and please let me know if you have any further questions.
Sam Daniel
Specialist, Care
MUSIC
http://www.ebay.com/sch/Consumer-Electronics-/293/i.?_nkw=behringer -  http://rd.bizrate.com/rd?t=http%3A%2F%2Freing.singlefeed.com%2Fr%2F%3Fcvsfa%3D3323%26cvsfe%3D57%26cvsfhu%3D393631313230%26cvsf%3Dhttp%253A%252F%252Fwww.interstatemusic.com%252F961120-Behringer-B215D-Active-550-Watt-2-Way-PA-Speaker-System-w-15-Woofer-and-Compression-Driver-B215D.aspx%253Fsku%253DSRSB215D%2526source%253DSingle%252BFeed_CASCIO%2526utm_medium%253Dshoppingengine%2526utm_source%253Dshopzilla&mid=38176&cat_id=11560000&atom=10398&prod_id=&oid=6060069795&pos=1&b_id=18&bid_=8&bamt=2fed68ce8c2e85f1&cobrand=1&ppr=2fec680123ae386d&af_sid=30&mpid=961120&brandId=965&keyword=behringer&rf=af1&af_asset_id=10&af_creative_id=2992&af_id=615103&af_placement_id=1 - Behringer
Sypa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sypa Quote  Post ReplyReply Direct Link To This Post Posted: 28 October 2017 at 4:42am
After 5 years my dcx failed mid gig, twice!
It just stopped sending signal to amps, completely reseting routing and settings . took me 20 long minutes to figure and set it all up again. Embarrassing to say the least never had this happen
Teknotice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teknotice Quote  Post ReplyReply Direct Link To This Post Posted: 18 February 2019 at 12:04pm
Who fixes ultradrives these days that we can mail units to? There is a queue of people looking for someone. Please let me know
'why on earth do you need this much amplification?!'
Biggus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Biggus Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2019 at 7:39pm
OK I’ve just got round to upgrading my ultra drive so thought I’d post on the poll that I’ve experienced no issues, I bought it second hand in 2009 and it hasn’t skipped a beat. The date code on the device is March 2006 so it hasn’t done bad at all :-)
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2019 at 4:51pm
just noticed noise on one output channel of an ultradrive. guess it's the fryin eggs that everyone complains about. unplugged and reconnected the three ribbon connectors and noise gone. first time I've had a problem with any of five ultradrives I've had. it says made in 2008.
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2019 at 12:13am
I had one do that, re plugged and it worked for a while then ended up soldering the ribbon to the pins, been good for nigh on 10 years since.
ermannofusini View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ermannofusini Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2019 at 12:02am
Wow
This page was generated in 5.171 seconds.
