Behringer Ultradrive Problems Poll |
Post Reply | Page <1 27282930> |
mini-mad
But some of us don't have old hardware and have to use USB.....
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 540 |
You can get a serial card for under a 10. Or I got a p4 desktop on free cycle the other year just for updating a few old omnidrives via serial.
msoundsystem
Young Croc Joined: 10 November 2011 Location: wales Status: Offline Points: 625 |
Il just buy a serial card as It can be handy for other things. Will get a card and update the dcx with the firmware, if it doesn't work or cure the fault I will swap the Eprom chip and try again. Will post update when tested. Many thanks!
Sam Daniel
New Member Joined: 27 March 2017 Status: Offline Points: 5 |
Dear msoundsystem, You're very welcome for the reply. Typically, our in house repair technicians will use an EPROM burner. However, we do not have a specific recommendation for a burner to use. Let’s keep in touch,
Sam Daniel Specialist, Care MUSIC http://www.ebay.com/sch/Consumer-Electronics-/293/i.?_nkw=behringer - Behringer |
Explicit 2
Registered User Joined: 02 May 2016 Location: Staffordshire Status: Offline Points: 91 |
Hello
I have a Behringer DCX2496 that I bought second hand, when I power it up after not using it for a while the LCD dsplay flashes for 1 to 3 minutes then it is ok and it works fine. Is it faulty? Is it going to die soon? Thanks
'Whether you believe you can or you can't your right' Im here to learn
Sam Daniel
Dear Explicit 2, Thanks for reaching out to us. The issue you are describing with your DCX2496 is definitely not an issue that we typically see with these units, and it could point towards a fault with the unit that may cause damage to the unit over time. Therefore, we would highly recommend having the unit looked over by a BEHRINGER authorized service center. For reference, the list of BEHRINGER authorized service centers can be accessed by selecting your country in the following link from the BEHRINGER website: http://www.music-group.com/brand/behringer/store-finder?type=POS I hope this helps and please let me know if you have any further questions. Let’s keep in touch,
Sam Daniel Specialist, Care MUSIC http://www.ebay.com/sch/Consumer-Electronics-/293/i.?_nkw=behringer - http://rd.bizrate.com/rd?t=http%3A%2F%2Freing.singlefeed.com%2Fr%2F%3Fcvsfa%3D3323%26cvsfe%3D57%26cvsfhu%3D393631313230%26cvsf%3Dhttp%253A%252F%252Fwww.interstatemusic.com%252F961120-Behringer-B215D-Active-550-Watt-2-Way-PA-Speaker-System-w-15-Woofer-and-Compression-Driver-B215D.aspx%253Fsku%253DSRSB215D%2526source%253DSingle%252BFeed_CASCIO%2526utm_medium%253Dshoppingengine%2526utm_source%253Dshopzilla&mid=38176&cat_id=11560000&atom=10398&prod_id=&oid=6060069795&pos=1&b_id=18&bid_=8&bamt=2fed68ce8c2e85f1&cobrand=1&ppr=2fec680123ae386d&af_sid=30&mpid=961120&brandId=965&keyword=behringer&rf=af1&af_asset_id=10&af_creative_id=2992&af_id=615103&af_placement_id=1 - Behringer |
Sypa
Young Croc Joined: 21 February 2013 Location: Croatia Status: Offline Points: 921 |
After 5 years my dcx failed mid gig, twice!
It just stopped sending signal to amps, completely reseting routing and settings . took me 20 long minutes to figure and set it all up again. Embarrassing to say the least never had this happen |
Teknotice
Registered User Joined: 24 March 2012 Status: Offline Points: 288 |
Who fixes ultradrives these days that we can mail units to? There is a queue of people looking for someone. Please let me know
'why on earth do you need this much amplification?!'
Biggus
Young Croc Joined: 02 May 2010 Location: Market Harborou Status: Offline Points: 1284 |
OK I’ve just got round to upgrading my ultra drive so thought I’d post on the poll that I’ve experienced no issues, I bought it second hand in 2009 and it hasn’t skipped a beat. The date code on the device is March 2006 so it hasn’t done bad at all :-)
snowflake
just noticed noise on one output channel of an ultradrive. guess it's the fryin eggs that everyone complains about. unplugged and reconnected the three ribbon connectors and noise gone. first time I've had a problem with any of five ultradrives I've had. it says made in 2008.
fatfreddiescat
I had one do that, re plugged and it worked for a while then ended up soldering the ribbon to the pins, been good for nigh on 10 years since.
ermannofusini
Registered User Joined: 18 November 2019 Location: Italy Status: Offline Points: 10 |
Wow
