  New Posts New Posts RSS Feed - Bertha BH-882 Build
Bertha BH-882 Build
 Post Reply Post Reply Page  <1 891011>
Jo bg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jo bg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 9:52am
Scaling everything will make a dfferent horn and lower the tuning. If you want to keep same tuning you have to keep same horn length and just find a way tofit bigger driver - check rear chamber too.
27 is already a low tuning, lowering it will probably lower efficency in exchange for not so useful 23hz output - unless you are going for cinema fx
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 10:39am
Originally posted by Twintub Twintub wrote:
21"/18" = 1.1667
Multiply all dimensions by 1.1667Smile
 Very bad idea.
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 11:27am
21"/18" = 1.1667
Nope.
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 11:46am
Regardless of the change of scale, what exactly are you trying to achieve using 21” drivers in a box of this style?
The function of a horn is to provide a better match between the driver and the air it is trying to move. In essence a horn increases the effective size of the drivers you are using. This makes the coupling between the box and the outside world more efficient.
Bigger drivers in a horn does not automatically mean lower frequency response or more output, although this may be possible with good design. But merely scaling up or down an existing design to suit your purposes does not automatically work, there are far too many variables for that.
Zitikaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zitikaz Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 5:50pm
HI
I would like to reach 25hz with good response natural bass, 21lw1400 seems suitable driver. Plan is to use Levan ext aswell
Maximum spl isnt primary goal, trying to get 25-60hz flat response.
or better look Rcf 18x401 and forget upscaling to 21"?
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 7:39pm
If huge SPL is not your main aim low tuned reflex would be my first choice. BMS18N862 is one option with its huge x-max.
Flat 25Hz Front loaded horns are going to be huge
Edited by csg - 08 January 2023 at 8:10pm
Ricky2023 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky2023 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2023 at 3:41pm
Hey does anyone have plans for mini Bertha looking to use a 12” subwoofer using it for outside movie nights and maybe some party’s probably going to use a sundown audio EV4-12 or a SA 12” or does anyone have a better solution for a portable subwoofer enclosure preferably a mini w bin or mini folded horn that is portable cheers Ricky
currently using a sundown audio EV3-12 in a 6th order parallel band pass for inside the house it does really well for movies and music it’s on roughly 750w
JACKCO520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JACKCO520 Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2024 at 1:28pm
hi
can someone tell my if the jbl 2269h wold work in state of the jbl 2242
thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote JACKCO520 Quote  Post ReplyReply Direct Link To This Post Posted: 05 December 2024 at 2:59pm
btw go see to realhorns de   you gonne see a horn for 2x15 " jbl think 2265 or 2267  only on facebook thx
Bams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bams Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2024 at 2:23pm
sorry to hijack this thread.. but JACKCO520 did you ever got around refurbing the abba rig?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JACKCO520 Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2024 at 2:42pm
hi
am still working on y will tray to send a foto in the summer of 2025
y have all ready 5 bass and 4 tops done whit new paint and handles
paint is tuff cab turbo blue handles penn elcom
regards jaak
Post Options Post Options   Thanks (0) Thanks(0)   Quote JACKCO520 Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2024 at 12:30pm
can someone tell my how to post a picture y don't now that
thx
