  New Posts New Posts RSS Feed - Bertha BH-882 Build
Bertha BH-882 Build
 Post Reply Post Reply Page  <12345 11>
T-Bone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bone Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2012 at 12:43am
Audio_AL did you use Baltic Birch throughout the build? I was thinking of using Arauco (7plies) internals and exterior BB. I plan to build these, how many did you use for internals 4X8? I plan to use them for portable PA rig and maybe use Marc's MKB's. Any other driver you suggest I get real good pricing on Faital Pro Neo's. Thanks!Thumbs Up
BASS, how low can you go!
Audio_AL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_AL Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2012 at 1:40am
Hello, I used all birch on mine. I'm not sure if it's Baltic or not. I never really kept track of internals vs externals but I think two sheet should do the inside. As for portability make sure you have the physical space and the man-power to move them around. 3.75 sheets @ 75lbs + 28lb driver makes this pig weigh ~310lbs! Check this thread out for a sim of a few different drivers. http://forum.speakerplans.com/eaw-bh-882-plots_topic33174_post709183.html?KW=Bh882#709183 . A great big thanks to Ibex for doing so!
Make it loud!
nomercy82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomercy82 Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 6:05pm
All of us bass heads wouls greatly appreciate your Extension Plans. I have 2 of the full sized cabinets, and an ep4000 running to them both. I RARELY get to use them because of their size. Mine are loaded with the Eminence Omega Pro 18a because they are cheap drivers and drop to 25 hz.
This is a thread where we discussed a ton of the RLA/ GSA/ SBS sound system stuff. Bertha Waldorf, Z array, and I'm still interested in the Levan extension.
http://forum.speakerplans.com/levan-horn-extension_topic58957_page1.html
Formalities aside, your build quality is great, and for all those others interested the name should say it all, Big Bertha ( mine atleast) are approcimately 365 pounds, but DAMN do they bring the bass.  The stories are true and I don't have the extensions...
Building a system in Pennsylvania.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Audio_AL Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2012 at 6:33pm
I havent had time yet to finish the extension but it will be built to spec. The only difference is it will be split into two pieces. As for the connection of all the hardware will be custom fabricated myself.
Make it loud!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomercy82 Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2012 at 11:04pm
Okay, I don't know the specs but in all the extensions I have seen. The outside edges are flat. GSA posted a picture of one being built on their facebook page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bone Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2012 at 7:42pm
I want to build these 2 first then maybe another 2 down the road with the Levan extension, but I only want to use the Faital pro 18HP1020 18" woofer? Lower Qts at .28 but should be good and quick for horn loading? Since these will be used as part of a 4way system I plan to use a 11 ply 18mm lite ply light in color but tough as BB, weighs only 53 lbs per 4X8 sheet.
Audio_Al any progress soundwise? Do you have frequency response with and without the Levan extension? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomercy82 Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2012 at 11:16pm
I'd recommend against using drivers that are not suited to this application. In SOME horns you can get away with using a different driver than specified, but the BH 882 will turn cones to dust in a few thumps.  fire up hornRESP, and test that driver out just to be safe. Nothing is worse than getting a new toy and breaking it.
Bertha drops LOW, and it's LOUD. off the top of my head I believe the full sized EAW Bertha is a 138 dB continuous sub woofer with a -3 dB at 38Hz.   That's with out the flare, with the flare the -3 dB point is in the 25 Hz range. Put a pair side by side, and that response will drop even lower, question is can you driver do that?
Dub Specialist View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dub Specialist Quote  Post ReplyReply Direct Link To This Post Posted: 11 November 2012 at 11:26pm
serious build man..sorry its just your comment nomercy82 that the best saying ive heard for shredding drivers ever...
"but the BH 882 will turn cones to dust in a few thumps"
lmao big time LOL..awesome dudeThumbs Up
Edited by Dub Specialist - 11 November 2012 at 11:27pm
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2012 at 12:11am
woah, obscene - make sure you weigh it!
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2012 at 12:31am
http://tcsounds.com/product/drivers/pro-5100-18-neo-driver/
30mm x-max, dual-laminated acrylic foam/fiberglass cone,$880.
djk
Goodvibetribe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goodvibetribe Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2012 at 12:46am
Nice work man, Seriously cant wait to see the extention once its finished.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nomercy82 Quote  Post ReplyReply Direct Link To This Post Posted: 12 November 2012 at 12:52am
Mother of God... You'd have to re-design the box to use that thing. the BH 882 only allows for something like 15 mm of xmax.
If you build with that driver, build 6 full sized bertha subs, DIY yourself some EAW DC1, buy a warehouse and retire a rich man.
