Bertha BH-882 Build |
Post Reply | Page <1 78910> |
UpComingSound
Registered User Joined: 21 June 2006 Location: United States Status: Offline Points: 393 |
so the single berthas would not be a good choice for mobile to have 4 of them compared to scoops or some other horn loaded cabinets ?
Lee In Montreal
Registered User Joined: 09 March 2011 Location: Montreal Status: Offline Points: 345 |
These Bertha's/Levan horns serve a different purpose than scoops. Look at most installations. Berthas + scoops on top for kick and upper bass. I suggest you build one and hear by yourself what you prefer.
BTW This is a Waldorf on top of the Bertha in the picture, not a JBL 4520. Edited by Lee In Montreal - 28 October 2016 at 3:18pm |
UpComingSound
Here go some Berthas outside of met life center I believe DJs were the world famous disco twins from nyc https://www.youtube.com/watch?v=xkhFbsAdQ0k
Edited by UpComingSound - 31 October 2016 at 8:01pm |
parabox
Registered User Joined: 03 February 2017 Status: Offline Points: 20 |
im somewhat intrested
BP1Fanatic
Registered User Joined: 02 August 2009 Location: Columbus, Ohio Status: Offline Points: 105 |
Still a classic thread just like the enclosure!
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 515 |
Bertha......A+.
Zitikaz
New Member Joined: 28 December 2022 Location: Estland Status: Offline Points: 4 |
Hei
HELP NEEDED! Can someone help me to scale it up a bit, to fit 21LW1400 and simulate it in hornresp? Plan is to build these monsters with 21" drivers :)
Zitikaz
How was the real results?
VECTORDJ
Bertha Hints - Make sure all internal Joints are Air tight.....I coated all Joints with Epoxy after building the Horn....A small Air leak will reduce Bass Output.....Make sure to get rear door very tight....The Klipsch Audio Papers has a Paper were Klipsch writes about Air Leaks....I found I like the Sound of two 1/2 Berthas better than one dual 18 Bertha......1/2 Berthas are also a lot less work moving.....VECTORSONICS
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
Paradise Garage. Found this photo on facebook today that I had not seen before.
(photo credit: Sun Palace Sound System) https://scontent.flhr2-3.fna.fbcdn.net/v/t39.30808-6/322395216_8458020110939578_8978909223271305896_n.jpg?_nc_cat=106&ccb=1-7&_nc_sid=730e14&_nc_ohc=ZmHC6Stiv2EAX9UAx7v&_nc_ht=scontent.flhr2-3.fna&oh=00_AfDvYDjwr1_tmokhm-elvEOJnxl5WnFl25umifQaQj3Hag&oe=63B3AC90 Edited by APC321 - 29 December 2022 at 8:09pm |
Zitikaz
Can someone help me to scale up drawings so i can use 21" driver?
Twintub
Registered User Joined: 24 April 2016 Status: Offline Points: 12 |
21"/18" = 1.1667
Multiply all dimensions by 1.1667
