Best combination for 15+2'' cab |
Post Reply | Page <123> |
corell
Young Croc Joined: 19 August 2013 Location: Berlin Status: Offline Points: 1161 |
15ndl76 is 180€ here. not that many high class ferrit 15" that are cheaper imo.
MarjanM
Whats your budget for this?
Tweeter_Box
Young Croc Joined: 23 June 2012 Location: London Status: Offline Points: 859 |
Marjan what driver do you recomend upto £150?
https://www.facebook.com/PurpleAudioRecords
Cobby
Registered User Joined: 06 January 2009 Status: Offline Points: 54 |
Discussing values won' do much good, I'm afraid, speaker pricing around here is almost random. Eminence Kappa pro 15a price is higher than the b&c 15cl76. But as a guide, I think the 15'' below U$200 and the driver under U$300.
I talked on the phone with the local B&C rep and probably I'm going with one of the two suggested designs, they use a 1.4'' instead of a 2'', but I guess it's enough. Only problem is that the suggested components go a bit over my budget, maybe I can replace 15nw76 with 15ndl76?
shagnasty
IMHO the Behringer EUROLIVE B215 is the best 15" +1" you can get, is sounds just as bad as the competition but @ £135 you won't be in tears when you finally bin it...
Which will be 120sec after you hear it... The 15+Hf has always been a total car crash, ok for an LE-400b that has been HPF @ 120Hz but to think a 15 will get upto a 1" whilst still doing bass and producing any mid at all is pretty silly. Nexo proved this, PS-10 great, PS-15 should never have been screwed together...
krazyneil
Young Croc Joined: 06 December 2007 Location: Bolton ,lancs Status: Offline Points: 1206 |
i used to have some TEK 15 +1 cabs which was loaded with pd153er and de25 crossed over around 2k if i remember rightly
although the cab was a little on the large size and fookin heavey it sounded very good , very smooth on the vocals and plenty of bass ,
so i think it can be done with the right drivers and the bms 1" comps can go down to 1200hz and still sound good so would probably be a good combo Edited by krazyneil - 15 March 2015 at 11:38pm |
GOD TOLD ME TO DO IT !!!!!
ceharden
15" + 1" is never going to work for anything other than cheap disco cabs. However it is possible to get good (not perfect but usable) results from a 15" + 1.4"/2". The PS15 is a bad example because they tried to make a full-range 2-way box so everything is a compromise. If you accept that you can lose a bit of low end, chose a lighter cone, nudge the crossover up slightly so the compression driver isn't straining at the low end then it's not too bad.
Incidentally, don't think that a 1.4" is inferior to a 2" because it's a lower number! Small format compression drivers usually have a 1.7" diaphragm and a 1" throat. Larger format drivers generally have a 3" diaphragm and either a 1.4" or 2" throat, often manufacturers do very similar drivers in both options. You'll probably find a better selection of 1.4" drivers and horns as they tend to be more popular nowadays. There are also some good 1.4" drivers with 2.5" diaphragms available now (eg the ND1424 I use) which won't go quite as low as a 3" but tend to work quite well in this kind of box. |
shagnasty
The (I think) BMS co-axial compression driver ( the one Bee used on his 12"+HF horn and Void use on the active Air10) helps with this as you can bring the 1" in @ 8Kkhz as the 2" runs out of steam but that doe leave you with a 3 way cab, which of course should be fully active!!!!!!
kevin tyler
Old Croc Joined: 15 April 2007 Location: Spain Status: Offline Points: 3402 |
I think the argument about whether 15 and 2 produces any mid depends on if the end user ( the audience)is physically listening out for mid, or just waiting for achey breaky heart?
Just sold my ad lib cabs, for 500 euros, JBL 226 and de75 horns, missing them already although I had not used them in years lol |
MarjanM
4550 can be crosed at 1 khz. That is plenty low to meet a 15 inch driver.
nickyburnell
Thanks(1)
[QUOTE=kevin tyler]I think the argument about whether 15 and 2 produces any mid depends on if the end user ( the audience)is physically listening out for mid, or just waiting for achey breaky heart?
/QUOTE] You'd think this was a hi-fi forum sometimes. Light cone 15 to 1" can do the job, agreed if you want 500w of 50hz you are going to lose mid. Millions of Peaveys, JBL's etc, etc doing a good enough job. I have four JRX115, the horrid comp has been replaced with a Beymcd10fe, the mid is actually very smooth when used as mid tops, and good enough all round full range for iPod parties. Crappy litlle 2.5" 15 driver that makes the compromise well. I have owned a pair of RCFL15c 06c (RMJ) with CP350ti on a 1.6 crossover, they were very good at bass, people looked for the sub that wasn't there, and local pub singers loved them. |
Cobby
I was using JRX115, reasonable for the size but dreadful HF. Guess anything from that would be an upgrade.
