Best kick bins between X1 & MT-130 ? HD15? MTH-30? |
Page <123 |
Adam_Iron_Horse ![]() Old Croc ![]() ![]() Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
You would need something like a berry ultradrive to put n delay to allign the speakers
ShokZi ![]() Registered User ![]() Joined: 05 August 2011 Status: Offline Points: 235 |
isnt ultradrive 3way? i'd need a 4way xo
djyves ![]() Young Croc ![]() ![]() Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
A ultradrive has 3 inputs and 6 outputs, so If you're going four way you'll need two of them.
Or you should consider buying a DBX or so with 8 outputs.
pfly ![]() Old Croc ![]() Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2828 |
Reasonable 8 output DSP would be Xilica XP-4080
Ultradrive would work with mono sub, mono kick and stereo midtops, that's the way I'm usually running it, its routing makes it possible, something that is not possible with DBX Driverack PA+ for example. MTH30 will probably sound quite bad doing mid/kick bass only. It is not designed for it. HD15, USB or ES18 would be the preferred ones for kick. HD15 being the smallest with smallest driver would generally be "fastest" and drop off highest, while USB is in the middle and many describe it being perhaps best sounding out of three with sufficient SPL for just about anything. In stacks it can be used without sub in most cases (excluding dub/dubstep/dnb naturally). ES18BPH is largest, drops lowest and can be used without sub, a bit like more hi-fi version of 1850 what it comes to frequency range. |
Ye I was going for mono sub and kick as there is not much point in stereo bass
KMB ![]() Registered User ![]() ![]() Joined: 02 October 2017 Location: Belgium (dutch) Status: Offline Points: 34 |
Hi guys!
Do you know some good Kick bins for x-over points 92-360hz? Its in my 4way pre amp. thanks
Keen ![]() Young Croc ![]() ![]() Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1177 |
why 360? mt130 play way lower
Because my pre amp has crossoverpoints of 90-360hz for kick. dont think i can change it. do you know some other bins that can play untill 360hz?
Letting your pe-amp determine what bins you build is backwards. Don't compromise the speakers, look at other options for xovers
Or go reflex 15's for now, then have the option of putting them in horns later.
JBK ![]() Registered User ![]() Joined: 03 March 2016 Location: Besançon Status: Offline Points: 251 |
most preamp builders can change the x-over frequencies of their machine, maybe try to contact yours, otherwise some sounds take the main output of the pre and run it through a lms / xover
Edited by JBK - 24 October 2017 at 9:29am |
https://www.facebook.com/rootikalvibeshifi
http://jbkaudio.fr https://www.youtube.com/playlist?list=PLKB8xPHqsVywM2EgtOaMjdgfIUf_-kFdV |
First I will try to reset the x-overpoints of my pre amp. otherwise i will have to make 15 inch reflex bins i think.
Page <123 |
