  New Posts New Posts RSS Feed - Best kick bins between X1 & MT-130 ? HD15? MTH-30?
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2011 at 10:39pm
You would need something like a berry ultradrive to put n delay to allign the speakers
ShokZi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShokZi Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2011 at 5:09am
isnt ultradrive 3way? i'd need a 4way xo
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2011 at 9:05am
A ultradrive has 3 inputs and 6 outputs, so If you're going four way you'll need two of them.
Or you should consider buying a DBX or so with 8 outputs.
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2011 at 9:25am
Reasonable 8 output DSP would be Xilica XP-4080
Ultradrive would work with mono sub, mono kick and stereo midtops, that's the way I'm usually running it, its routing makes it possible, something that is not possible with DBX Driverack PA+ for example.
MTH30 will probably sound quite bad doing mid/kick bass only. It is not designed for it. HD15, USB or ES18 would be the preferred ones for kick. HD15 being the smallest with smallest driver would generally be "fastest" and drop off highest, while USB is in the middle and many describe it being perhaps best sounding out of three with sufficient SPL for just about anything. In stacks it can be used without sub in most cases (excluding dub/dubstep/dnb naturally). ES18BPH is largest, drops lowest and can be used without sub, a bit like more hi-fi version of 1850 what it comes to frequency range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 09 August 2011 at 2:36pm
Ye I was going for mono sub and kick as there is not much point in stereo bass
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2017 at 12:05pm
Hi guys!
Do you know some good Kick bins for x-over points 92-360hz?
Its in my 4way pre amp.
thanks
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2017 at 1:00pm
why 360? mt130 play way lower
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2017 at 3:00pm
Because my pre amp has crossoverpoints of 90-360hz for kick. dont think i can change it.
do you know some other bins that can play untill 360hz?
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2017 at 2:25am
Letting your pe-amp determine what bins you build is backwards. Don't compromise the speakers, look at other options for xovers
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2017 at 2:27am
Or go reflex 15's for now, then have the option of putting them in horns later.
JBK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JBK Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2017 at 8:55am
most preamp builders can change the x-over frequencies of their machine, maybe try to contact yours, otherwise some sounds take the main output of the pre and run it through a lms / xover
Edited by JBK - 24 October 2017 at 9:29am
https://www.facebook.com/rootikalvibeshifi
http://jbkaudio.fr
https://www.youtube.com/playlist?list=PLKB8xPHqsVywM2EgtOaMjdgfIUf_-kFdV
KMB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMB Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2017 at 9:00am
First I will try to reset the x-overpoints of my pre amp. otherwise i will have to make 15 inch reflex bins i think.
This page was generated in 0.080 seconds.
