  New Posts New Posts RSS Feed - Best lighting desk for around £200
Electrikal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Topic: Best lighting desk for around £200
    Posted: 29 April 2013 at 12:05am
Anybody got any suggestions on the best lighting desk for around £150-200?
Cheers!
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 12:14am
chamsys dongle and laptop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 12:24am
Dude you are a hero, i was looking at something similar but it was £150 and a £90 software license. What software would you recommend with this?
nineleaves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nineleaves Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 12:49am
http://chamsys.co.uk/magicdmx
chamsys magic q & dongle is a one stop solution.. you use their dongle with their software (downloadable off site)
http://chamsys.co.uk/download
this licence gives you access to running the software on pc but you can only trigger shows/elements via pc controls.
if you want a control surface, those cost considerable money, enough that they dont advertise it on site:
http://chamsys.co.uk/pcwingcompact
their concept is also available as a dedicated 1 box controller:
http://chamsys.co.uk/mq100expert
...if you want hardware faders, and just need to control some rudimentry scenes/sequences say for a bunch of parcans and not tons of intelligent heads, then a small dmx console like behringers eurolite might be a fair bet.
http://www.gak.co.uk/en/behringer-lc2412-eurolight/952?gclid=CKzkpYLH7rYCFcNQ3godgHYAQQ
horses for courses, depends on your lighting needs/expectations :)
on the otherhand.. if the budget has allowed for purchase/hire of professional heads which can easily cost thousands (or stratopherically more) each, then expect that the control hardware required to run them comfortably to cost abit.. all out concert lighting gets so expensive, it makes the pa side of things look like the cheap part of the investment ;) its definately a key part of the equation and shouldnt be skimped on.
in anycase learning on a simple controller with some basic cheap lighting is going to be a great way to learn the rudimentry stuff whilst planning for fancier things in the future as needed :)
Edited by nineleaves - 29 April 2013 at 1:02am
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:01am
...for that sort of money i just bought the basic one.... i have to learn to use DMX at some point!
cheers for that fella
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:03am
Post Options Post Options   Thanks (0) Thanks(0)   Quote nineleaves Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:19am
im no seasoned veteran ;) ..i just use what i get along with personally & not got bucketloads of experience of the myriad of other controllers out there.
never heard of the transcension jc1 before ..it falls into that category of "budget generics" ..it seems aimed at allowing basic show control specifically for moving mirror type fixtures, with only 64 channels availble and equating to 8 heads max based on 8 channels each ..its not going to exactly reprosent great value if you want more than that form it, probably avoid.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:24am
If you want to do 'proper' lighting, get a proper lighting desk, or at least some software that behaves like one.
You will learn how to do it 'right' and many of the skills are semi transferable between the big common manufacturers.
I've never understood the mindset of controlling thousands of pounds worth of moving heads on a £200 disco controller.
An Avo Azure can be had for under £1k these days and is a capable little desk.
Or even an old Masterpiece if you can spend the time getting to know it.
Something with physical buttons and faders is a big bonus too, clicking stuff on a screen is a really nasty way to interact with a lighting rig.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:26am
P.s. buy the MagicDMX dongle and a cheap ELO touchscreen, you'd be surprised how far this combo will take you
Post Options Post Options   Thanks (0) Thanks(0)   Quote nineleaves Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:31am
in keeping it simple, just follow nortys advice.. he really does know what hes doing ;) :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:53am
....can i not just use any touch screen? those ELO ones cost a fortune and i could prob get hold of one for free from somewhere
sorry for the hi-jack
Post Options Post Options   Thanks (0) Thanks(0)   Quote nineleaves Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2013 at 1:56am
any touchscreen thatll work with your pc in the first place will do :)
(im not aware of any exceptions here, elo just make decent ones)
