BEST PLAN FOR HEAVY LOW MID BOX |
steflion
Joined: 23 March 2008 Location: France Status: Offline Points: 99 |
Topic: BEST PLAN FOR HEAVY LOW MID BOXPosted: 12 April 2008 at 10:28am |
Greetings, I would like to build my own box for my heavy low mid section and I want to know if the fane COL18XB driver is a good one or the PD186 for this application and which are the best plan for them?
Give thanx for your upcoming answer
One Love
Disco Stu
Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2492 |
Posted: 12 April 2008 at 10:55am |
Please define frequency range of low mid. It is unlikely an 18" will work well if its over the frequency range I consider low mid, a 15" will probably be better. Stu |
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
Tekasis
Posted: 12 April 2008 at 11:41am |
I've used Fane Col 15B & PD158 in standard relex cab & was pleased with the results. Was wondering if they'd work as good or better in a horn-loaded style cab ?
**Heavy Weight-Line**
A home without books is like a body with no soul. |
