Best Plan for P. Audio SD-15 |
Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
AgentLovely
Registered User Joined: 15 January 2009 Status: Offline Points: 13 |
Posted: 22 January 2009 at 6:49pm |
Ive looked all over and found nothing referencing this subwoofer. Any help would be appreciated!
AgentLovely
Here are the specs if that helps.
Glenn
Registered User Joined: 01 October 2008 Location: Australia Status: Offline Points: 197 |
Staiper Microscoop?
AgentLovely
Ive looked in the scoops forum and went to a MSN website with staipers plans but could not find that scoop? Do you know the location to find this plan? Looks interesting! Do you use this scoop personally?
staiper
Registered User Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
.. May I help you :
PLANS Parts - CUT LIST .. I'll check what simulation "say" .. when I return home. |
bitzo
Registered User Joined: 20 November 2007 Location: Italy Status: Offline Points: 977 |
good to knows! could you post the sim data input? I'm pretty curious :D
(and lazy) Edited by bitzo - 02 February 2009 at 7:41pm |
staiper
AgentLovely
The P. Audio SD-15 basket size is around 190 millimeters...I bet the back end will not fit into this design :(
Teunos
Don't forget to set path difference to roughly 9.5 cm.
Best regards,
Teun. |
AgentLovely
Decided to go with the BR115. Here are the 2 boxes I built!
This is my first time building any boxes. Tested it outside my doors with a TAPCO 2500 power amp. 30 seconds after I turned it up 6 people walked outside with angry looks on there faces. <3
AgentLovely
staiper do you have a alternate link for the microscoop plans and cutlist?
