  New Posts New Posts RSS Feed - Best recommended box for RCF L18 P300
mylesound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mylesound Quote  Post ReplyReply Direct Link To This Post Posted: 19 February 2008 at 4:25pm
RIP DJ lalo.
He made 850's sound better than scoops rite there in trini.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2008 at 2:38am
a scoop, not all scoops
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2008 at 9:29am
Originally posted by sirck50 sirck50 wrote:
i DJ Mostly outdoors and need a nice box design for my two L18P300's. I want the sound to be extremly loud, and travel extrtemly far. Thanx in advance. Oh i'm from Trinidad in the Caribbean by the way.
You wont get sub that is extremely loud and throws extremely far with only 2x 18" drivers. LOL
And I hope you have at least 800W rms of amp power for each driver.
Originally posted by Rengade Project Rengade Project wrote:
Check out scoops and folded horns
L18P300 will self destruct in scoops without much power being supplied.
WSX will sound good outdoors if you have about min 4x of them per stack, and are >=20 meters away from the cabs.
1x L18 loaded, 2x18 reflex will sound good in very, very small venue.
186 Horn/Cerwin Vega SL36 would probably be best all rounder for this driver.
Edited by levyte357 - 20 February 2008 at 9:44am
sirck50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sirck50 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 12:40am
well i do plan to invest in sum more 18's. The RCF are easy to obtain in The Caribbean.
So which is it, the 186 or the WSX?
Hello!!!
Rengade Project View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rengade Project Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 1:19am
Get more 18" woofers partner. Pick what is convenient and solid for your use,listen to other systems that are doing what you are planing(not just Davey Scorpion).
MUSIC SWEET,www.myspace.com/renegadeproject
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 1:48am
To be quite honest, the absolute best thing for you to do is sell the RCF's and get Void V18-1000.
Then you can build either Superscoops, my scoop or WSX, and get extreme SPL with just 4x cabs inside or out. As long as you have min 800W per driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sirck50 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 2:37am
I cannot get Voids in Trinidad pal. The DJ speakers available down here are:
Selenium
RCF
Ciare
18SOUND
JBL (bUT VERY EXPENSIVE)
tHERE ARE A FEW MORE BUT THESE ARE THE POPULAR ONES.
Hello!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rengade Project Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 3:40am
What no becker or metron available in TNTShocked I am surprisedLOL
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 7:35am
Selenium
RCF
Ciare
18SOUND
It sounds like WSX is it. There is something slightly bigger on http://www.speakerstore.nl/index.php?l=nl&pg=11&c=18
Havent heard of anyone building it though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sirck50 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 12:52pm
beckers an metrons were popular in the 80's an early 90's but they stopped bringin them here so the only ones available are used (An 90% sure they will be repaired not with original parts)
Hello!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 1:15pm
Selenium
RCF
Ciare
18SOUND
I know WSX with V18-1000 is immaculate outside, but in small venues indoors with L18P300 I think it might be a bit tame.
Can you borrow a Vega SL36 off someone? May be suprising with L18P300. Will drop deeper than 186 Horn, but larger.
If you then build SL36, it will sound better than an  original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sirck50 Quote  Post ReplyReply Direct Link To This Post Posted: 21 February 2008 at 1:53pm
I dont no anyone here with a SL36 SO I HAVE TO DEPEND ON other ppl's experience with both enclosures to tell me what's better.
Hello!!!
