"Best" Reflex drivers atm? |
Post Reply | Page <12 |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Interesting I've never tried any bms cone drivers, but lots of comps.
For bassreflex I mostly used older drivers so far, like 18p300 / 18lw1400, the last is better. Heard good about b&c & fane xs too. |
MarjanM
Alex, i used a custom version of 18NLW9600 which became the today's 9601 :-). I compared the 18N850, 18SW115, Oberton 18NXB1600 and Faital 18XL1600. 18Sound won. |
tv00
Looks good for horn too
But why is it THAT expensive, because of neo-tech? Rcf lf18x451 is almost half the price It moves the same air & takes the same power, lower resonance and higher sensivity is the main difference, should play louder at a lower cost according to specs, but you never know. |
MarjanM
Sorry but overall RCF quality built and technology is on a completely lower level.
You are comparing 15kg ferrite magnet driver with a 12kg neo driver. See where the difference is huge? Also the cone on the 9601 is a pure art. 4.5 icnh VC vs 5.3inch VC. And so on.
tv00
Know what you mean, remember from L18P300 vs 18LW1400 in the past:-)
I'd love to try some of these drivers! Very satisfied with LF18X451, we had neighbor complaints yesterday xmax-testing two scoops, one was wearing earplugs to sleep in another building 100+ meter away |
MarjanM
Check out the cone and VC :-)
tv00
NICE:)
That cone looks brutal with all the bumbs in it, I every so often wondered why? Can't they make it straight:) Probably not that easy when it's "molded" and the surface dries out of control It could be to stiffen or kind of brace the cone, but then a star pattern would be better i guess. |
Dub Specialist Sound
That cone does look beefy man,
ie stronger/stiffer cone?
MarjanM
Oh yeah, very strong.
Teunos
still slightly disappointed they do not use a true seperated double spider like PD on the NLW.
Best regards,
Teun. |
70,s hero
Young Croc Joined: 14 December 2014 Location: bristol Status: Offline Points: 637 |
You could look at the Peavey Lomax 18. it goes to 500HZ is about the third the price and is more sensitive I think from memory. it kicks well too, has only one spider so that probably explains the increased HZ, AROUND 12lbs heavier than a neo but has a kevlar impregnated cone. I suppose Peavey have produced a very stiff and strong cone that only requires one spider which is good as you get the extra sensitivity and response.
Top banana
