Best scoop to run in singles |
Post Reply | Page <123> |
feliz
Registered User Joined: 23 April 2012 Location: brighton Status: Offline Points: 108 |
I dont get how a 15 and a comp is common combo but an 18 with an 8 and comp couldn't fill a similar role, with these drivers at least a lot of emphasis would have been on a light responsive assembly.
MarjanM
You need to learn a bit more about dispersion.
feliz
True i don't know much about it but how does an extra 3 inches take something from common bass-low mid driver found everywhere to extremely directional above sub bass, i'm here to learn.
odc04r
Look up the definition of driver beaming.
feliz
ok cheers so i have till 763 HZ to cross it over, so no problem in that case?
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4538 |
Lots of scoops can play low in singles. There are many different designs and drivers. Which have you tried as that will explain your findings.
feliz
i was looking at hogs as they are apparently much cleaner than more traditional designs, i do like my dub but i listen mainly electronic so i would like a bit of flexibility. Only reason i'm looking at scoops is efficiency over a reflex box.
KingGwarn
Registered User Joined: 19 March 2016 Location: Brighton Status: Offline Points: 193 |
I'll have some hogs in a few weeks which you'd be welcome to check out/see how low they go on their ones...if you haven't decided by then anyway!
Soundman inna Brighton town
King Gwarn Sound System |
feliz
That would be awesome, cheers.
nickyburnell
Best scoop to run in singles.
http://forum.speakerplans.com/staiper-micro-scoop-on-winisd-hornrsp_topic52339.html |
feliz
cool, would it get down to 40Hz?
nickyburnell
I did one and put an 18 in in for an experiment years ago. 40hz F3 out of anything horn loaded in singles is difficult. Startec SBH is huge but seems to do it. Minis need EQ to do lower than 45 usually, but that's OK, thats what we do. The link I did for the Micro Scoop is best with a PD1550, it then can run 45 to 100 without kicks, it sounds, "scoopy". No doubt you can eq the hell out of it to get the elusive 40hz but at the end of the day it's a 15. Single non reflex cab for me would be the Tham 15 with the B&C TBX or the Oberton 700 . Not a scoop, not a dirty sound like a scoop, if you want scoops, you want more than one. Only my opinion BTW |
