Best SOUNDING 18 inch. in a 150 litre enclousure. |
Page <1234> |
| Author | ||
levyte357-
Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8517 |
Posted: 19 May 2014 at 1:28pm |
Zebulba1
Joined: 03 March 2014 Location: Denmark Status: Offline Points: 32 |
Posted: 19 May 2014 at 1:34pm |
Ok i see.
Any advice regarding the port depth. Like the rule of thump regarding the depth and the sound..Like if the port its too Deep it will sound slow, and if it is too short it will sound too boomey
jbl_man
Joined: 12 January 2005 Location: London. Status: Offline Points: 11308 |
Posted: 19 May 2014 at 2:24pm |
'Rule of thump...'
Joined: 02 April 2004 Location: United States Status: Offline Points: 5365 |
Posted: 19 May 2014 at 2:46pm |
The length of the port is based on the tuning frequency. What you are mentioning has nothing to do with the depth of the port. For what you are aiming for, you would have better options with fifteen-inch drivers, as you are not looking to achieve a very low response. If you have your heart set on eighteen-inch drivers, just build the G Sub and use the FANE 18 XB. The G Sub was designed for that driver. Best Regards, |
Zebulba1
Posted: 19 May 2014 at 8:15pm |
Ok.
G-sub is unfortnally not an option, since im only myself to carry the speakers. What ment ragarding the "rule og thump on the port length" was if there was some kind of coheasion between the port length and the sound it makes. Im not thinking tuning and port turbolens-wise. More like sound quality wise. Like if a short port made a certan kind of sound, and a long port another sound. Brg.
Posted: 19 May 2014 at 8:48pm |
I don’t know who is filling your head with this nonsense but, I would strongly suggest you stopping listening to him/her. If the G Sub is too big then just cut them in half. Surely, you can carry half a G Sub? Nevertheless, I think it is time for you to start learning the basics http://www.danmarx.org/audioinnovation/theories.html http://www.linearteam.dk/default.aspx?pageid=winisd Best Regards, |
djeddie
Posted: 19 May 2014 at 9:13pm |
Also the Fane Sovereign 18-800 sims very well in a 140 - 160 litre cab.
Zebulba1
Posted: 19 May 2014 at 10:13pm |
Hi.
No one fills me head with nonsens (other than meself). It was just a thought i had...sorry if it was silly. I guess better safe than sorry...and now i know, so thanx. And also thanx for the learning links. ill get to it right away.
KidCreole
Joined: 06 November 2013 Location: London (East) Status: Offline Points: 3580 |
Posted: 19 May 2014 at 10:17pm |
Zebulba1
And no problem to carry half a g-sub btw.
Allredy read the link regarding design theroy, and i use bass box 6 pro to sim.
Foca_Dacian
Joined: 05 February 2011 Location: Romania,Cluj Status: Offline Points: 118 |
Posted: 29 June 2015 at 9:51am |
What T/S tell you that a driver works in a small or in a large vented enclosure?I want to build a 155 liter box tunned to 40 hz with an 18 inch and want to double check if it works.Simulations say so.
F3@45 hz,I have to say decent for such a small enclosure. Qes 0.3 Qms 13.6 Qts 0.3 Vas 369.4 liters Fs 30 hz X-max 9.25 mm Edited by Foca_Dacian - 29 June 2015 at 10:06am |
DMorison
Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1740 |
Posted: 29 June 2015 at 12:45pm |
It's an interaction between several, so it's best to model to be sure. As a very rough rule of thumb: If Qts is 0.4, then the driver will achieve a flat response with F3 = Fs in a box equal to Vas. If Qts is lower, then it will want a box less than Vas to stay flat, but F3 will be higher than Fs, as you've already found. If Qts is higher than 0.4, you may need a box larger than Vas to stop it pushing the response up in a hump about half an octave above tuning. HTH, David. |
Page <1234> |
