  New Posts New Posts RSS Feed - Best speaker for solar powered van alpine a32f
louiejcruz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote louiejcruz Quote  Post ReplyReply Direct Link To This Post Topic: Best speaker for solar powered van alpine a32f
    Posted: 25 April 2021 at 6:14pm
Hi there
I have this amp https://www.alpine.co.uk/p/Products/SingleView/S-A32F installed in a camper van powered by solar.  Everything's up and running but my speakers and knackered and hoping to buy something a little more substantial anyway.
Criteria:
Looking for loud / crisp / clear sound as opposed to really loud base techno / acid / bass music / electronic music
Suitable for small outdoor party
2 x speaker 1 sub preferred
I'm looking to order something quickly if possible so custom builds aren't an option right now
sprinter size so much be able to fit inside but also don't want anything overkill in size.
Specs for the amp are as follows...
Max Power Output Ratings
  • Total Max Power: 640W
RMS Power Ratings
  • Per Channel into 2 Ohms, 14.4V (≤1%THD+N): 4 x 80W
  • Per Channel into 4 Ohms, 14.4V (≤1%THD+N): 4 x 55W
  • Bridged into 4 Ohms, 14.4V (≤1%THD+N): 2 x 160W
Sound Tuning
  • Crossover: Variable LPF, 50-400Hz (-12dB/oct )
  • Crossover: Variable HPF, 50-400Hz (-12dB/oct )
General
  • Power Requirements: 14.4 V.DC (9 - 16 V allowable)
  • Input Sensitivity (RCA Input): Hi: 0.5 - 10 V Lo: 0.2 - 4.0 V
  • High Level Input with automatic power on
  • Cable size: Power Cable AWG 8, speak Cable AWG 10
  • Frequency Response (+0, -3dB: 1W into 4 ohms) for CH-1/2/3/4: 10Hz - 30kHz
  • THD+N (@ 10W into 4 ohms): <0.03%
  • THD+N (@ 50W into 4 ohms): <0.08%
  • Damping Factor: >100
  • Signal to Noise (@ 50 Watts into 4 Ohms): >98dB
  • Weight: 1.9 kg
hectorberman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hectorberman Quote  Post ReplyReply Direct Link To This Post Posted: 26 April 2021 at 11:55am
Theres lots of options, and people here are likely to want a bit more info on intended use before they can reccomend you specific items :)
Those community tops on fb would do you proud with a small reflex subwoofer, and upgrade to a tham 12 or two in time ;)
Good luck with the search, hope you find something before your birthday!
This page was generated in 0.062 seconds.
