Best way of cnc rebating cabs? |
bmx42
Registered User Joined: 21 September 2015 Location: bristol Status: Offline Points: 88 |
Posted: 16 January 2018 at 9:07pm |
Hi all
I'm just writing a cnc program for a cab design and wandered what's considered the best way of rebating the internals into the side panels etc? I was unsure of doing tabs on the internals with a slot around a mill deeper then the tab. Wouldn't have any build issues with this and can easily get over build tolerances from cnc. Or to do full length rebates so the entire internal panel is rebated into side panel. This would be stronger but more precise so could create build issues from tolerance build up. Wandering what others have done for this? Thanks |
ceharden
Normal practice is just to rebate the entire length of a panel.
Tips: 1) Check the thickness of the wood. It might be nominal 18mm but could be half a mm or more either way. 2) Don't forget to allow space for glue. You're probably going to want to rebate by at least 0.5mm more than the thickness of the wood. Same goes for depth of rebate too.
odc04r
I'd do full rebates, put some holes in for dowels for even easier alignment if you're feeling posh. Don't know what CNC you have access to but a vacuum table helps a lot for sheet work as you can trust your heights then. As Chris says, measure your sheet thickness first at multiple points (take an average of a few) as they are invariably at least half a mm off.
SouthwestCNC
If your just working on the design without the sheets. Adding .5mm to std sheet thickness works well most the of time unless you get badly stored ply.
bmx42
Great thanks everyone this has really helped :) yeah there pretty big machines with vacuum tables. Unfortunately I won't be able to take measurements of the sheet sizes as I'll have to make a special order with our works supplier for 18mm BB just before I want to run them through. Got a small window at work to use cnc while on down time so just trying to make the most of it. I've used a rabbet lock style join on the exterior panels
Edited by bmx42 - 17 January 2018 at 8:29pm |
