Best way to seal a driver in acabinet ? |
Post Reply | Page 123> |
Safetyman
Young Croc Joined: 08 February 2009 Location: Brighton, East Sussex Status: Offline Points: 555 |
Posted: 04 November 2017 at 4:56pm |
Had an issue with one of my 2x8's at a party last weekend...
There was little, or no hf coming out of it at the start of the gig, but it was back to 'normal' by the end of the gig. Now, this was last used outdoors until there was a sudden cloudburst. Luckily the speaker was under a gazebo on a tripod stand at the time, but near the deluge, so it did get a bit wet as the wind was blowing the rain in . I thought it was probably a partly corroded speakon connector, so have given it the Deoxit D5 treatment, to see if that makes a difference. Testing it all again tomorrow, but I may have to look inside and take the three drivers out , to check for corrosion . Not done this before on these speakers, which need to be re-sealed/air-tight on the front baffle to sound sweet. How do you re-seal the drivers so that they are air-tight ? Cheers |
Protect your hearing, and feel the music.
MU South East Roving Safety Rep. |
Hemisphere
Lots of ways you could do it. Thin strip of rubber sheet would be one, or run a line of gummy glue stuff (technical term) that never sets solid around the cutout is another.
One way I've been thinking of recently that would give a fantastic seal but might need reapplication if you ever took the driver off, would be to run a line of hard setting resin around the cutout and wait for it to almost set, then attach the driver while it's still in a tacky, semi-flexible state (maybe with a strip of greaseproof paper or similar around the flange to protect the basket)
Edited by Hemisphere - 04 November 2017 at 6:23pm |
Safetyman
Thanks for the advice. I was thinking along the lines of a thin strip of foam rubber, but that probably would not seal it completely. It would have to be something that was easily releasable/re-useable, for maintenence purposes, though. Any form of glue would seem to be a permanent solution, but impractical should the drivers need to be removed/replaced at some point in the future.
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Weather Stripping. Closed cell foam with adhesive backing. Compresses down easily.
Safetyman
Thanks, that is what I was thinking.
Hemisphere
Glue isn't necessarily permanent. I'm thinking of that gummy stuff they use to stick gift cards inside birthday cards etc. Designed to stick but designed to be removed as well.
Mikkel
Young Croc Joined: 17 May 2013 Location: Huddersfield Status: Offline Points: 549 |
Blu tak? |
fatfreddiescat
What wxactly are you trying to seal? Chassis to baffle?
Hemisphere
No not blu-tak. It's much more like actual glue.
snowflake
I'm going to go out on a limb here and say foam tape
Safetyman
Yes, for sealing chassis to baffle
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
How about a tube of gasket sealant?
Kinda does what it says on the tin. |
