  New Posts New Posts RSS Feed - Beware the one eyed monster!
 Post Reply Post Reply Page  <1 3456>
The Builder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Builder Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 11:28am
I have the prototype and 186's, I'll try them at some point soon...
It just is.
kiriiz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kiriiz Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 2:59pm
Plots plots plots :)
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 3:31pm
here are some plots, I used the input parameters from darkmatter:
input screen:
black is void v18-1000 and grey is pd186, (the fane 1000 is the same as v18-1000, at least i don't see any difference between the two)
all drivers do reach xmax at 42 hz with 1000w, so anything above 42 hz under 1000w should be fine.
Edited by djyves - 14 June 2010 at 3:32pm
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 4:08pm
Originally posted by djyves djyves wrote:
, the fane 1000 is the same as v18-1000, at least i don't see any difference between the two)
really?????
theyre fairly different drivers
i was potentially planning 4 of these with the fane 1000
bitzo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 4:16pm
to me HR isn't good to predict this cab response.
Edited by bitzo - 14 June 2010 at 4:18pm
Oscar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oscar Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 5:20pm
Originally posted by darkmatter darkmatter wrote:
I wonder whether underhung coils (XBL^2?) would get the most from tapped horns?
I'm not sure if I read your thought in parenthesis correctly, but XBL^2 isn't underhung, since it has multiple gaps
http://www.acousticdev.com/Files/XBLDetails.pdf
Smile
Edited by Oscar - 14 June 2010 at 5:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 7:01pm
really?????
I mean, I don't see an difference in the graph, but I will try again.
Edited by djyves - 14 June 2010 at 7:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 7:05pm
here is a good graph of the fane 1000 vs void v18-1000:
the fane 1000 has a higher excursion around 60 hz, they both reach xmax with 1000w 41 hz
Edited by djyves - 14 June 2010 at 7:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 7:12pm
black is fane 1000,
grey is v18-1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 7:14pm
at +/- 40 and 60hz the fane 1000 goes over xmax
the v18-1000 does not go over xmax at 60 hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitzo Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2010 at 9:24pm
akabak sim with b&c 18tbx100, eleven section, I take care of magnet diameter in order to reduce the 10th section.
TDA-Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TDA-Audio Quote  Post ReplyReply Direct Link To This Post Posted: 28 June 2010 at 8:19am
my be ? recalculated 1x12" ? 2x12" ?
