Beyma CP755Ti HF : Need Help ASAP |
nkspeaker
Registered User Joined: 26 August 2008 Status: Offline Points: 1 |
Posted: 26 August 2008 at 3:42pm |
I tried using Beyma 2 Beyma LF 15G450 & 1 HF Beyma CP755Ti with Beyma FD212 Crossover. We tried this combination in a small setup where we found the HF amp goes to clipping mode and finally my two HF diapharm is gone. But the sound quality is extremely high.
But i could see the HF has more response than the LF & force of the HF is more.
With the setup i also tried using the same LF & different HF,it works fine.
Can someone help about this issue. SPent lot of money on Beyma.
Please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
(SoundcreationaudiO)
Registered User Joined: 09 October 2007 Location: Wales Status: Offline Points: 306 |
are you bi-amping your cabs? use an active crossover, scrap the passive one. |
Bespoke
Old Croc Joined: 20 August 2007 Location: Gone Status: Offline Points: 1886 |
I use the 15g450n and the CP650it bi-amped they work very well together but cant quite understand what your doing
So what are you using to power the tops ? mids ? and what crossover are you using ?
think he's bi-amping a cab, and using 2 amps to feed the passive crossover..?? or have i got the wrong end of the stick
