Big 12v amps |
Page <1 234 |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 2594 |
I've looked at a lot of batteries now. LiFEPo4 is a lot lighter for the same capacity, but they don't seem to be that much physically smaller - about 80% of the physical volume for same kWh. Have I got this right? I'm more concerned about the size than the weight so might end up going for lead.
bass*en*mass ![]() Old Croc ![]() ![]() Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 3905 |
the size difference depends on capacity, the lifepo4s need balancers and bms etc, those dont grow much with capacity, hence smaller ones are closer in size to lead ones, bigger ones much smaller.. weight is just one bonus, the stability on discharde/charging-current is much higher than lead, it also rises significantly with capacity, the discharge doesnt drop voltage as quick as with lead, hence load/current stay more healthy too.. (a decent capacitor/power cap might help on lead batt.) |
are these too cheap to be true?
2/4/6 pcs 3.2V 100Ah lifepo4 Iron Phosphate solar cell Electric Car battery Lot | eBay |
studio45 ![]() Old Croc ![]() ![]() Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3783 |
At £70 each plus possible import taxes, no not really *too* cheap...I'm cynical today so I'll say they probably won't test at quite 100Ah each - but that's not a crazy low price for prismatic 100Ah cells. Liitokala is quite an established brand now.
snowflake, dont forget to buy/account for suitable balancers and a bms.. ;) (those thin sheeted cells also require aditional care re. safe mounting, specially for mobile setups..) SH/slightly used `integrated`60Ah ones go for about 150ish quid, if its just for some bletooth cabs without real lowend and rather small amps i guess those should give a better bang per buck diy :) |
on balance I was thinking of getting an integrated one - all the problems are dealt with
I'm thinking of powering 2*15" FLH with it. Efficiency is a lot better than a vented box so 60Ah might actually give some decent output for a few hours. Looking at 100W solar panels to keep topped up. With British weather can probably rely on that giving about 20W on a cloudy day ![]() I ordered the Banda Elite 4000.4 amp yesterday. Will have loads of headroom but that should help maintain efficiency. I think this is the best value new integrated battery from a UK supplier I have seen: Ultramax LI84-12, 12v 84Ah Lithium Iron Phosphate LiFePO4 Battery | eBay I will keep a lookout on ebay for a few weeks and see if anything used comes up. Edited by snowflake - 20 January 2021 at 10:27pm |
yeah, integrated balancer+bms module would do, just make sure it really matches your capc. i am awaiting an esx QE80.4 this week, 240w at 4ohm bridged should allow for some headroom running efficient flh subs/horn loaded Tops.. :) on a cloudy day solar panels are at about 5-10% wp, 100w? a standard 300w+ panel is fairly cheap nowadays.. ;) those used 60Ah ones seem to sell well here, will pn you a link asap! |
they just get a bit big and cumbersome over 100W. weight seems to go up more than linearly too as they have to support their own weight. I could rig up three or four 100W panels on the trailer but they would be in different orientations - guess I would just have a separate cheap charge controller for each panel. |
eshroom ![]() New Member ![]() Joined: 26 August 2020 Status: Offline Points: 13 |
I made my battery using these cells. https://www.aliexpress.com/item/32970111444.html true capacity 6ah - not 7ah as advertised, but this is still very good for size/weight. It wasn't complicated to put together and I integrated a BMS.
Individual cells give you the option to distribute the battery within a space, rather than having a big battery block that needs a singe big space. You could split the battery in 4 and put it in 4 corners for example. I split mine to be on either side of my speaker's centre brace. I paid about £45 for 12 cells and BMS creating a 12ah 19.8v battery. So I guess a 12v true 84ah battery would set you back around £160-£170 if you DIY it. Or if you want higher voltage, you just wire it straight to the voltage you require instead of losing energy with a step-up converter. ![]() Edited by eshroom - 21 January 2021 at 1:42pm |
Page <1 234 |
