BIG Amps Competition! |
Page <123> |
| Author | ||
pfly
Joined: 25 October 2007 Location: Helsinki, Fin Status: Offline Points: 2827 |
Posted: 16 March 2012 at 10:59pm |
Am I wrong when I'm thinking of PKN making use of 3 phase supply properly, it should be 3*32A*400V = 38400W going in. Also on top of that the condensor banks need not be anywhere near as big as with single phase since the three phases pretty much rectify the supply already?
Someone please correct me. |
audiomik
Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2956 |
Posted: 16 March 2012 at 11:41pm |
Yup, you will get 300Hz ripple at 50Hz supply frequency from a 3 phase input full wave rectified to a single DC supply. You still need Smoothing Caps but their capacity can be reduced pro rata in terms of the required stored charge compared with single Phase supplies. Have built a number of 3 Phase input high current DC supplies for industrial use; the downside is requiring three transformers plus rectifiers, but the output Current rating can be very much improved with the increase in ripple frequency as well as the reduced loading of each of the three transformers. For direct off line DC supplies feeding into Switch-mode PSU's the same applies, but without the need for transformers. hope this answers you, loads more on this in PSU design Papers published on't 'net Mik Edited by audiomik - 16 March 2012 at 11:48pm |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
Pahlavan-i
Joined: 04 August 2011 Location: United Kingdom Status: Offline Points: 197 |
Posted: 17 March 2012 at 12:08am |
whoa ![]() ![]() |
Pahlavan sound =/= Sepas gozar-am
Earplug
Joined: 03 January 2012 Location: Europe Status: Offline Points: 7752 |
Posted: 18 March 2012 at 10:18am |
I think the original equation is correct. Remember that the usable voltage will be (root3)*400V, so: Power Available = 3*32*400/(root3) = (root3)*32*400 Or have I missed something there? |
MessyM2k8
Joined: 29 October 2008 Location: Norwich Status: Offline Points: 690 |
Posted: 18 March 2012 at 10:38am |
Yeah original equation is correct. see here http://www.powertogo.ca/three_phase_load.htm. The only thing is in britain its 415V+/- 6%(i think 6% may be 10%now) not 400
Edited by MessyM2k8 - 18 March 2012 at 10:39am |
Motion54
Joined: 13 November 2010 Location: London Status: Offline Points: 1753 |
Posted: 18 March 2012 at 10:40am |
"4800w/14800w=0.32"
What does this mean? Is this efficiency of the amp in turning mains power into output power? |
dubplate specials
Joined: 04 December 2007 Location: United Kingdom Status: Offline Points: 26 |
Posted: 19 March 2012 at 4:38pm |
so out of all the amps which is the most effiecient one and also cost effective
love conquers all things,with wisdom get understanding.....big up to everyone who reads this
Peter Papp [PKN]
Joined: 17 June 2010 Location: Budapest Status: Offline Points: 203 |
Posted: 20 March 2012 at 11:40am |
The three phased power is: Suare Root of 3 * 32A * 400V = 1.772 * 32 * 400 = 22170W if the power factor is close to 1. Most of PKN amps have Power Factor close to 1 anyways. I do not want to comment the other amps however this power value in our case represents what average scaling of the power distribution system required to operate this amp close to its maximum power with "normal loads" and dense but "normal music signals" :-) . It does not mean that the amp would not pull out more from the AC line if needed but the typical circuit breakers have this capacity for extra current for few seconds. |
Earplug
Posted: 20 March 2012 at 11:48am |
I´m not too sure what that means either, maybe the magick factor of the amp? ![]() |
tmg
Joined: 19 March 2009 Location: Bristol Status: Offline Points: 261 |
Posted: 20 March 2012 at 11:55am |
how on earth can you fit 40K into a box that small?
Peter Papp [PKN]
Posted: 20 March 2012 at 12:18pm |
Hehe Maybe how big is the LIE factor? Smaller number = Bigger lie :-) It looks the ratio of max. (average) power draw vs. peak output power. without figure of conversion efficiency. All amps have internal energy storage, some less few with more... The peaks served from the "internal energy storage bank" while the store is charged by the power supply. It is not important factor while you do not have very dense signals, however if you push the amp close to his limits the difference becomes significant. Practically the lower power draw amps easier to operate anyways. |
djkeet
Joined: 26 December 2011 Location: England Status: Offline Points: 465 |
Posted: 20 March 2012 at 12:46pm |
Sounds like you've got more chance of frying your speakers if something goes wrong
Soundbite
Page <123> |
