Big techno rig |
Post Reply | Page 12> |
Bdkcambo
New Member Joined: 22 June 2018 Location: Cambodia Status: Offline Points: 6 |
Posted: 22 June 2018 at 10:09am |
hello! We run an outdoor techno rave and are looking to build a stonking big sound system, got about $10k to play with. Any ideas? Its in Cambodia so I'll have to import drivers, I can get hold of crown amps, and wood/labour is cheap so the bigger and crazier the better!
Edited by Bdkcambo - 22 June 2018 at 10:17am |
citizensc
Hi Cambo
Before people will be able to help you, they will need some more info. Crowd size? Indoor/outdoor? How big is the room if indoor? Exactly what crowns are available to you? For how much? Whos $ are you talking about? US? AUS? NZ? Edited by citizensc - 22 June 2018 at 1:00pm |
BJtheDJ
Young Croc Joined: 28 November 2012 Location: Bristol Status: Offline Points: 886 |
OP has already said OUTDOORS, and looking left underneath his name tells you he's in CAMBODIA.
It's a difficult choice, would you rather have:
A: A vegan son. B: An OnlyFans daughter |
citizensc
Ah, didnt see the outdoor bit .. its the 5th word. Cambodia doesnt have $ as a currency. If he means Riel then he has a budget of 1.84 pounds (lol)
Hemisphere
The bigger and crazier the better? Reckon we could convince you to build a massive straight front loaded bass horn that sits under a stage or is that too big and crazy?
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 684 |
As it's for techno use lots of 15s.
nickyburnell
Agreed 100%
mini-mad
Build a metric f##k ton of 1850... like... 32 of them and then hang a pair of splayed tops from each side of your 4 high 8 wide coupled 1850 horns and just power ally the bass straight through the crowd.
Job done. Edited by mini-mad - 22 June 2018 at 9:24pm |
woody2
Old Croc Joined: 04 March 2010 Status: Offline Points: 1726 |
$ is king in cambodia everywhere takes it, the cash machines payout usa $ |
valve head777
Old Croc Joined: 27 July 2012 Location: East Sussex Status: Offline Points: 1781 |
True dat $$$$$
Edited by valve head777 - 22 June 2018 at 10:34pm |
toastyghost
And enjoy the side lobes pissing off the neighbours for miles around! Are people recommending 15s because they’re ‘faster’? That’s because most 15” designs simply don’t go low... Edit: is this for Kerfuffle? Edited by toastyghost - 22 June 2018 at 10:50pm |
Hemisphere
