  New Posts New Posts RSS Feed - Bill Fitzmaurice Omni 10.5 (built by Insomnia)
Disco Stu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Topic: Bill Fitzmaurice Omni 10.5 (built by Insomnia)
    Posted: 10 April 2008 at 11:36pm
Since good things often come in multiples heres another cab to add to my collection.
Omni 10.5 with Deltalite 2510 and BK plate amp.
I needed a new backline cab as my old one (see final pic) is getting a bit tattered and is an awkward shape to move around! Its still great though - 2x10 PD loaded + Powerline Piezo.
So I have finally got my arse in gear and got this new BFM cab to replace it with a built in 600W amp.
I played out with it the other night, in a local trades and labour club with a covers band....
Hmm problems.... I couldnt get it quiet enough, I had to turn down the gain on my keyboard, for some reason the plate amp has a minimal gain setting that isnt quite 0, and on heavy organ sounds, it was a little too loud.
I have never been used to hearing myself so clearly so it kinda scared me a bit!
Overall the sound was good, a little less bassy than I am used to but thats ok, the cab is on a kickback stand so that would explain why.
I can hear myself a lot better though, the lower notes on the piano seem somehow clearer, despite not having as much <100Hz output as before, plus the cab is now pointed up at my ear which is definitely an improvement.
I want to get a cheap 9/10/12 band EQ at some point to have a bit of tone shaping EQ potential so the response can only get flatter
It also weighs next to nothing with a Neo driver and digital lightweight amp!
So very useful, very flexible and pretty cheap, certainly much better quality sound than if I had bought a purpose built keyboard amp, plus its a horn, so everything just sounds cleaner and punchier.
Stu
Edited by Disco Stu - 10 April 2008 at 11:43pm
All you need to know is:
My acts:
Jake_Fielder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 9:00am
That looks really nice stu, any idea what that cab is tuned to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 12:47pm
Well the full Omni 10, which is a double 10" is tuned to 60Hz and is double the size so......
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 12:48pm
Its meant to be a full range box BTW, large rear chamber, ports into horn throat.
Stu
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 1:10pm
Stu
It doesnt look like its ported into the horn throat....?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 4:02pm
Just below the driver in the second pic is the slot that ports into the throat.
Stu
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 4:10pm
Why does it vent to the outside aswell then!? seems odd, or is that a secret that only the purchasers of his designs get to know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 4:14pm
It doesnt
If you mean the vertical strip down the side of the cab in the 2nd pic, thats where the tweeters go.
Stu
Edited by Disco Stu - 11 April 2008 at 4:16pm
My acts:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_Fielder Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 4:23pm
Hahaha ok!
I thought it was an enormous port!
Im really stupid sometimes!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Disco Stu Quote  Post ReplyReply Direct Link To This Post Posted: 11 April 2008 at 5:21pm
That would indeed be an enormous port for a 10" box, you would have to expect some performance from a 10" to warrant a port that big.
Stu
My acts:
