Billyware server |
tendril
Registered User Joined: 22 July 2004 Status: Offline Points: 334 |
Posted: 24 January 2005 at 5:03pm |
I'm not trying to bitch too much here but the microsoft server that
this site is hosted on sucks. keep getting this message when moving about the forum: Microsoft OLE DB Provider for SQL Server error '80004005' [DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied. /forum/common.asp, line 260 Any plans to move it to an apache server running on linux? I'm sure we could have a whipround to come up with the funds needed for a year or 2s hosting. some great deals out there. I use purple-paw for £75 a year: 500MB mySQL 5GB transfer/month full 24hr support running on apache/linux etc etc. just a thought. |
Tendril
A mistake is a mistake only if one learns nothing from it. |
Jogge
Registered User Joined: 09 August 2004 Location: Belgium Status: Offline Points: 63 |
same here
Always listen to experts. They'll tell you what can't be done and why. Then do it.
Lasse Lukkari
Young Croc Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
The database server seems to go down from time to time.
Pinheiro
Registered User Joined: 27 February 2004 Location: Portugal Status: Offline Points: 320 |
Hi the same here most off the time is off line Yours Vitor |
tendril
Ok so lets have a whip round and get some cash to move it to a better server... up for it Vivo if we raise enough dough?
I'll pledge £20 for a start. whos up for it? |
Tendril
PISSHEAD
Young Croc Joined: 24 July 2004 Location: West Midlands Status: Offline Points: 584 |
Pledge 2o pounds as well. |
The 'drunken master' strikes again.
laxskan
Moderator Group Joined: 25 February 2004 Location: poole Status: Offline Points: 73 |
The SQL problem are related to the sever and are currently being resolved "hopefully" Modern micosoft sql servers are pretty good these days, and it would be problematic to go over to unix system cheers |
Dom
Old Croc Joined: 25 February 2004 Location: United Kingdom Status: Offline Points: 1700 |
Is there any reason why ever since you changed the site I no longer stay logged in???
laxskan
Try clearing your cookie cache this should sort out the login problem. The SQL server has now been upgraded so the SQL errors should be sorted out, please let me know if you experince any more probs cheers
Andrew
Registered User Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
[DBNETLIB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied. /forum/functions/functions_common.asp, line 710 (About 3.15pm UK time, 28th Jan 05) |
tendril
well that's what you get with billyware :( 'free the source' Edited by tendril |
Tendril
Andrew
Is it just me? |
