  New Posts New Posts RSS Feed - BMS 18n850 vs. VOID V18-1000
Bob45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob45 Quote  Post ReplyReply Direct Link To This Post Topic: BMS 18n850 vs. VOID V18-1000
    Posted: 21 December 2006 at 1:55pm
Hi Guys,
I am going to build some X1s next week but I’m not quite sure what speaker I should use.
On the one hand there is the famous Void V18-1000, which should work very fine in the X1.
On the other hand I read that the BMS 18n850 works also well in X1 - even better than the Void.
http://www.bmspro.info/photos/bmspro_info/18n850.pdf
Now I ask you which one I should use.
B0B
Tekasis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tekasis Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2006 at 6:54pm
I wish I knew mate. I had a look on that link, the woofers looks good, & they compression drivers are very sensitve, seems like their all made in Germany.
Tried looking for prices in UK sterling but no joy, not even sure if we can get them here.
Good luck on your X1s Bob & choice of driver.
Rog View Drop Down
Rogers Archive Posts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2006 at 9:16pm
The choice as they say is entirely up to you Bob.
One of those divers has an efficiency of 1.55% and will produce 94.05 dB for 1w/1m.
The other has an efficiency of 3.64% and will produce 97.77 dB for 1w1m.
Rog.
Racks&Stacks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Racks&Stacks Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2006 at 10:19pm
rog, where do you get the 94db rating?
Mike Severloh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Severloh Quote  Post ReplyReply Direct Link To This Post Posted: 21 June 2007 at 12:48pm
Hi,
and there is even more variety to come:
a) rumor has is there´s 2 versions of the BMS 18n850, and
b) Void´s continuing development led to the new V18-1200, a hell of a LF driver ... !
Anyone checked these ones out ?
Edited by Mike Severloh - 21 June 2007 at 12:48pm
Mike Severloh.
