BMS 18S430v2 reconing |
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1085 |
Posted: 10 December 2018 at 2:07pm |
So at the moment I'm going to recone my first speaker, so I'm definitely a newbie to this.
I've watched videos for reconing speakers but I still have a question. With the recone kit I've got contact adhesive, which I think is for the gluing of the; spider, cone and the surround to the chassis. But then I also have a little bottle with coating (white stuff), where is this used for?
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2581 |
there could be 2 possibilities. the bottle could be Latex for cone treatment - if it's liquid or it could be silicone for treatment of the cloth exterior suspension. (this usually looks like a cream)
smitske96
I would say it has almost the same thickness as wood glue.
Here are some pics of the little bottle:
studio45
Yes that will be for cone treatment. Apply one coat evenly to the cone and surround with a paintbrush, once all the other glues are dry. There shold be just enough in that bottle to do the job. It is water based.
Mircea Bartic
That is latex for the cone treatment
it will dry transparent so don't worry if the cone becomes white at first ;)
smitske96
Thanks for the help
Btw; removing the glue ,really is a pain in the ass... I finally removed it from the basket Next thing tomorrow is removing the residu from where the spider was. I used sticker remover until now, but it didn't help much. If anyone has any tips, they are always welcome
toastyghost
A Dremel, and some serious solvents.
KDW32
Young Croc Joined: 09 April 2010 Location: Green Hell Status: Offline Points: 525 |
yes that with acetone If you can find a lazy susan in your local charity shop it will help loads
Edited by KDW32 - 10 December 2018 at 11:13pm |
studio45
Acetone doesn't really attack contact adhesive - you need some toluene or xylene aka "glue remover". It will turn it soft and sticky so you can roll it off in little balls - it will stick to itself like Blu-tack does. I normally use a sharp chisel to get most of it off, and then a Scotchbrite pad with some more solvent to scrub the last bits away (Green plastic scrubber)
You'll find the glue remover is very volatile and evaporates almost as soon as you put it on, so pour out a small amount into a narrow vessel and use a small paintbrush to keep dabbing it on. Do this with the windows open, or you'll accidentally get high as f*ck.
smitske96
any experience with that? So I found out we had a Dremel al the time but I removed most of the glue with a good chisel.
smitske96
The recone was successful , now my last question.
Must the spider also be coated with the coating?
