  New Posts New Posts RSS Feed - BMS 18S430v2 reconing
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Topic: BMS 18S430v2 reconing
    Posted: 10 December 2018 at 2:07pm
So at the moment I'm going to recone my first speaker, so I'm definitely a newbie to this.
I've watched videos for reconing speakers but I still have a question.
With the recone kit I've got contact adhesive, which I think is for the gluing of the; spider, cone and the surround to the chassis. But then I also have a little bottle with coating (white stuff), where is this used for?
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 2:43pm
there could be 2 possibilities.
the bottle could be Latex for cone treatment - if it's liquid
or it could be silicone for treatment of the cloth exterior suspension. (this usually looks like a cream)
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 2:55pm
I would say it has almost the same thickness as wood glue.
Here are some pics of the little bottle:
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 3:11pm
Yes that will be for cone treatment. Apply one coat evenly to the cone and surround with a paintbrush, once all the other glues are dry. There shold be just enough in that bottle to do the job. It is water based.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 4:51pm
That is latex for the cone treatment
it will dry transparent so don't worry if the cone becomes white at first ;)
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 10:12pm
Thanks for the help Thumbs Up
Btw; removing the glue ,really is a pain in the ass...
I finally removed it from the basket
Next thing tomorrow is removing the residu from where the spider was.
I used sticker remover until now, but it didn't help much.
If anyone has any tips, they are always welcome Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 10:54pm
A Dremel, and some serious solvents.
KDW32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KDW32 Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2018 at 11:10pm
yes that with acetone
If you can find a lazy susan in your local charity shop it will help loadsWink
Edited by KDW32 - 10 December 2018 at 11:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2018 at 2:09pm
Acetone doesn't really attack contact adhesive - you need some toluene or xylene aka "glue remover". It will turn it soft and sticky so you can roll it off in little balls - it will stick to itself like Blu-tack does. I normally use a sharp chisel to get most of it off, and then a Scotchbrite pad with some more solvent to scrub the last bits away (Green plastic scrubber)
You'll find the glue remover is very volatile and evaporates almost as soon as you put it on, so pour out a small amount into a narrow vessel and use a small paintbrush to keep dabbing it on. Do this with the windows open, or you'll accidentally get high as f*ck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2018 at 8:01am
any experience with that? LOL
So I found out we had a Dremel al the time Embarrassed but I removed most of the glue with a good chisel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2018 at 12:23pm
The recone was successful Smile, now my last question.
Must the spider also be coated with the coating?
