BMS 4590 and 2230 horn |
zigzagwanderer
Registered User Joined: 01 February 2021 Location: sw uk Status: Offline Points: 48 |
Posted: 14 December 2021 at 6:32pm |
Has anyone any experience or thoughts on using a BMS 4590 compression driver coupled with a BMS 2230 horn (700hz cut off )
I'd like to use this combination above some fane 12" sealed mids and cross over at 1000-1100hz but ive been told ideally i should crossover 1 octave higher than the horn cut off frequency Is the above BMS combination likely to cross over comfortably at 1000-1100 hz Ive also looked at the BMS 2236 horn but I would prefer the wider dispersion of the 2230 The P audio PH-4525 horn was another possibility but I cant find any available in the UK Any info would be gratefully received before I buy anything thanks |
VECTORDJ
Young Croc Joined: 11 June 2006 Location: United States Status: Offline Points: 513 |
4590 with their passive crossover at 6300 Hz sounds outstanding...Have tried them with many horns...The diff horn designs changes the sound a bit but still good ......I find the sound a little soft compared to large format drivers with metal domes...Almost too Hi-Fi....I wonder if BMS ever tried metal vs poly. I set the active crossover (DSP) between 400 Hz to 1500 Hz depending on horn size....Again all good...Allows a wide range of System designs....My two test samples
are 8 ohms.... I also have Neo ones and they seem a tad brighter.....VECTORSONICS
vertx
Young Croc Joined: 14 March 2012 Location: Sydney Status: Offline Points: 578 |
I use the 4590 on the 2236 from 600hz up 24db LR. If you're going to only run from 1000hz up there are cheaper options that will work:
https://www.bcspeakers.com/en/products/hf-driver/2-0/8/de785tn-8 https://www.rcf.it/de_DE/products/product-detail/nd950-2-0/292813 But then from 1000hz up you could use a smoother horn with a smaller exit and that opens up other compression driver options too. |
fat_brstd
Old Croc Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2125 |
My wife has 2 of the 4590 on I think the 2230 and it is excellent crossed at 900hz above 4 sealed 12" (B&C 12NDL76) and the sound is very very impressive (I use a 10" + 1" to cover the same range and her ones sound better) This driver/horn combo is very loud and you need a lot of mid to keep up. It will also show any lackings in your amplifier, we tried quite a few different amps before settling on the QSC CX902 which is an outstanding sounding amp.
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
zigzagwanderer
thanks everybody for the replies
After much deliberation Ive decided to try something else instead !
