BMS 4592ND performance on a 250Hz tractrix |
Page <1234 5> |
ShokZi
Posted: 17 June 2014 at 7:19pm |
im also interested as i had my eye on those horns but couldnt find enough data on directivity to take such a leap of faith
DJ-Dulux
Joined: 24 August 2009 Location: Kenilworth, UK Status: Offline Points: 382 |
Posted: 23 October 2015 at 2:02pm |
Any updates, looks like a really interesting project....
Dupe... |
Dupe...
Sapro2
Joined: 31 January 2015 Location: Somerset Status: Offline Points: 352 |
Posted: 23 October 2015 at 9:52pm |
Agreed, i looked up Stereolab and all i found was a band. I would love more info, they look beautiful, good horns tend to lok right and hat is a corker. I am a fan of tractrix my lower mid horns are based on the tractrix curve.
Do they have a website? |
Splat Soundsystem
Baby Sham pram Soundsystem Sapro - SoundCloud https://soundcloud.com/sapro DJ Sapro. West country free party DJ and Producer. |
DJ-Dulux
Thanks(1)
Posted: 23 October 2015 at 10:24pm |
Dupe...
odc04r
Joined: 12 July 2006 Location: Sarfampton Status: Offline Points: 5469 |
Posted: 24 October 2015 at 9:09am |
Lovely horns, fairly pricey but I bet the quality is good. Bet they could be great for HiFi customs if you had a nice 1"/1.4" driver sitting around
DJ-Dulux
Posted: 25 April 2016 at 4:26pm |
Did you finish your work on these, I am wanting to build a bigger 12V rig over the next year and these may do the trick?
Dupe... |
Dupe...
SouthwestCNC
Joined: 27 November 2015 Status: Offline Points: 824 |
Posted: 05 March 2017 at 11:57pm |
Wow Corian, nice inert material and impressive thermoforming. 10mm that is interesting it's only available in 9 or 12 which likely means that 2mm is stretched out in the thermoforming process. No easy task. Problem with it is its brittle, a good impact and it shatters, it also scratches very easily. Not sure how well it would fair in a touring application. Need to be boxed for certain.
csg
Joined: 17 September 2007 Location: bedford Status: Offline Points: 6085 |
Posted: 06 March 2017 at 7:53am |
Unfortunately, whilst on axis sound was superb, these, and all other tractrix flares i have played with ( 18 sound and a couple of unbranded ones i picked up somewhere) suffered from too much HF beaming, giving an inconsistent sound and making splaying multiple boxes impossible.
With flares, you cant beat the physics unfortunately - and i had to compromise and use large CD flares that whilst ultimately sounded poorer on axis were array-able and far more consistent across their coverage area giving a solution which was workable. For me, tractrix flares have one use - hifi where you have one focused listening position and need very high sensitivity through the use of very low powered valve amps, and thats about it.
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Posted: 06 March 2017 at 10:35am |
Chris did you try the 4594Nd on the 18sound XT? With FIR filtering applied to correct some of the dispersion anomalies it's damn good - but as you say it's not ideal for more than two per side
Nor is it cheap! Edited by toastyghost - 06 March 2017 at 10:35am |
SouthwestCNC
Posted: 06 March 2017 at 2:32pm |
toastyghost
Posted: 06 March 2017 at 3:22pm |
Well there must be an issue with that sim because they provide their own isobars, polars, DI and so on here:
http://www.eighteensound.com/Portals/0/PDFs/XT1464.PDF |
DJ-Dulux
Posted: 06 March 2017 at 3:32pm |
Really difficult to compare as the scales (dB and frequency) are so different?
Dupe...
Dupe...
Page <1234 5> |
