  New Posts New Posts RSS Feed - BMS drivers in X12
BMS drivers in X12
jerronimo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerronimo Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2009 at 5:11pm
I contacted Mark Oldroyd at precision devices for more info, the pd121, pd122 and 12sb30 will all work in a compact BR design.
The 12sb30 will give more low freq. output in sacrifice of the mid freq., the other way around for the 122 and 121 respectively 3.47%  & 5.10% efficiency.
The 122 has a higher xmax(4mm) then the 121(2,5mm) so I gather that higher xmax and more low extention will result in lower efficiency.
As I'm planning on using X1's for subbass from 30-80 hz, the 121 will not be the right choice I think as it needs to be crossed at 100+ hz.
So now I don't know what to do, go for the 12sb30 for some low end extention or one of the lighter coned mid oriented drivers?
So that leaves the 12sb30, PD122 and the BMS320 but now I hear some of the 18sound and B&C models also sound very nice!
Why are there so many choices? hahaha lol!
audionik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audionik Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 2:43am
Hi Tony, wich one between 12 n610 and 620 would you put with 1,4" 1200hz x-over 350 w for the 12"?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote audionik Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 2:48am
Edited by audionik - 18 November 2010 at 2:49am
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 8:57am
Thanks.
If you are talking about a single 12" then the 610. The 620 has too much power handling for a 350w X-over.
What X-over are you talking about?
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote audionik Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 12:27pm
x-over 24db 1200 hz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 12:45pm
No I mean is this a X-over that is for sale and if so do you have a link?
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote audionik Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 1:09pm
Electronic crossover with dsp
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 1:17pm
It depends on the final use. If you are always going to use subs then the 610 is the one to go for.
However if you need them to be more of a full range box as well then get the 620. I use the 620's in my double 12" + 1" boxes and they make a pretty impressive job when being used full range. They use a fair bit of low end EQ ( +5db, 60hz Q=2) but seem to lap it up.
Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 2:05pm
2X12N802 plus 4592 :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 2:52pm
Marjan, Strangely enough just got some 802,s in to try, a pair with the co-ax top would make a formidable mid-top. Not got enough X-max though to be used to their max potential full range.
I am using the 802's in my own single 12" ers with a 4552nd comp.
Tony
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 3:47pm
hi tony any pix of your 12"ers?
Lignum_ww@icloud.com
GNKaudio@icloud.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 18 November 2010 at 3:56pm
I am just about to spray them having finally gotten around to buying a pressure pot system. As soon as they are presentable I will stick some up.
Tony
