  New Posts New Posts RSS Feed - "Boat Party" System
"Boat Party" System
djstefanos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Topic: "Boat Party" System
    Posted: 16 May 2010 at 3:39am
Right, we currently use 4x cerwin vega JE36 18" 106db 1w 1m and they perform well. But I want something smaller, more efficient and lighter. They are big to maneuver around the stairs of the boat and a pain in the arse.
with them we use 2 x 215+2"
suggestions?
pile of 12" reflexes?
Edited by djstefanos - 16 May 2010 at 3:47am
system:
20 x MA W8L
12 x MA W8LC
12 x MA W8LM
20 x MA S-218
8 x D.A.S. ST-112
brokenjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brokenjoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 3:50am
Ev mt4.
or majicbox.
would be ideal .. not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 4:01am
???? this?  will not fit through the boat's opening. 2 feet wide.
system:
20 x MA W8L
12 x MA W8LC
12 x MA W8LM
20 x MA S-218
8 x D.A.S. ST-112
FlipC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlipC Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 4:49am
Build a TH.
Go to DiyAudio.com  in the subwoofer section. Read the TH threads. Pick a design. Build. Be amazed.
Wolla.
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 5:42am
tapped horn?
system:
20 x MA W8L
12 x MA W8LC
12 x MA W8LM
20 x MA S-218
8 x D.A.S. ST-112
B.P.Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B.P.Sound Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 7:24am
If your 'Boat Party' is on the Thames in London you will have even toughter noise restrictions this year, where the boat can't turn off the limiter once away from pier like previous years. Best go for 4 cabs in the corners. I use 2 x event 3000's and 2 Event 1000's. the D.J. Kit takes the most time to set up. Otherwise 4 x 15" bass cab with poll up to F8's or something. It is all down to loading time you only get 45mins on most Thames boats. and remember when removing the kit the ramp back upto the road is alot steeper on low tied. Which is always when you are removing the kit.
http://www.londoneventrentals.co.uk/ https://www.facebook.com/LondonEventRentals
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 8:49am
the "boat parties" are in Malta, no sound restrictions except when docked. Music always starts when 200m away from land.
Edited by djstefanos - 16 May 2010 at 8:52am
system:
20 x MA W8L
12 x MA W8LC
12 x MA W8LM
20 x MA S-218
8 x D.A.S. ST-112
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 9:12am
106dB in the 40hz~50hz range, about 10dB more than a CV in that range.
http://www.danleysoundlabs.com/pdf/TH%20115%20Spec%20Sheet.PDF
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote djstefanos Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 12:22am
hahahaha, too good to be true?
Edited by djstefanos - 17 May 2010 at 12:23am
system:
20 x MA W8L
12 x MA W8LC
12 x MA W8LM
20 x MA S-218
8 x D.A.S. ST-112
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 5:29am
I'll wager you any amount of money you like:
The BFM design will not measure as advertised, but the Danley design will.
"Danley Sound Labs data is gathered by Pat Brown’s ETC company which insures our customers get honest third-party gathered data and not some home cooked set of numbers that may be misleading or overly optimistic at best."
Edited by _djk_ - 17 May 2010 at 5:33am
djk
mykey- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey- Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 6:55am
COUGH!!!!Shocked what were those measurements cooked on, gas mk4?
is that for 1 cab or 4?
rich_gale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich_gale Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:42am
4x good 15" reflex's and some 802's on poles.  sorted.
This page was generated in 0.110 seconds.
