Boominator build (UK)... |
Page 123 11> |
DJ-Dulux ![]() Registered User ![]() ![]() Joined: 24 August 2009 Location: Kenilworth, UK Status: Offline Points: 367 |
![]() ![]() ![]() ![]() ![]() Posted: 08 May 2014 at 4:10pm |
Updated 12-5-14 with latest design and links for people in UK sourcing hardware. Updated 14-5-14 with weight of components. Updated 2-9-14 I am back on it. Minor updates. Updated 10-3-15 Back on it, again ready for summer. Updated 28-3-15 page 7 parts are arriving. Updated 3/4-4-15 page 8 weight discussions. Updated 4-6-15 page 9 CNC wood arrives and we confirm the weight! Updated 3-8-15 page 10 the build starts. Updated 21-8-15 page 10 almost complete Updated 10-11-15 page 11 some comments on using epoxy resin Hi all, I am about to start building a Boominator, after much thought about doing my own design, its become clear that significant development has been done on this design and I don’t have time to re-invent the wheel. So here is the plan so far: Speakers Low Freq – Eminence Basslite S2010 *
4 - 6.4kg High Freq – P-Audio PHT-407N * 4 - 1kg Will probably get from www.bluearan.co.uk Timber Machine cut 12mm filmed 9 ply birch
ply, will try and source WisaForm Birch Glue West system Six10 epoxy and jenny brushes from East Coast Fibreglass X-Over MiniDSP 2*4 + 2 way Advanced 21 from www.accusafe.nl with plug in from www.minidsp.com Amplifier MaxAmp20 * 2 from www.accusafe.nl Battery 12.8V / 10Ah LiFePO4 battery from www.euroenergy.co.uk - 1.5kg Management Solar Will be added at some point Overall Weight 8.9kg (speakers and battery) 11kg (cabinet) ##kg (electronics) Will obviously post updates on here, but any obvious comments on the above and any amplifier advice? Will not be starting build for another month, so plenty of time to refine ideas. Thanks, Dupe… Edited by DJ-Dulux - 10 November 2015 at 1:50pm |
Dupe...
Saturnus ![]() Old Croc ![]() Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2020 |
Right now the obvious choice for amp is miniDSPand 2 maxamp20.
That being said, I'm currently in the last steps of finally making a passive filter that will fit both a HP10W and a S2010 crossed to a PHT407N by only moving a single resistor from one position to another. If made on a PCB it would just mean moving a single jumper. Specifically it's a resistor being moved from being either parallel to the series resistor or the parallel resistor on an L-pad so a non-critical component. You should also note that PCBs are finally being made for the shiznit amp, now renamed to cAMP for trademark reasons. I could write a whole novel about the features that will have but I'll list some of the main features here: - available late June/early July 2014 (Is our best estimate right now). Priced around $200 retail. - up to 2x50W into 4 ohm at 0.2% THD Here I have to note why it says "up to", it's because it runs directly on a 12V battery but if input signal is turned up beyond a certain point an internal dc-dc converter kicks in and raises the voltage as needed up to 24V. The dc-dc converter is one of the most efficient ones ever made in this voltage range and the efficiency in this set up is even better than what the chip manufacturer states is possible, average efficiency when on is around 97% (for the dc-dc converter). - Idle consumption: 470µA or 0.006W Here I also have to note that the amp have a higher idle consumption as long as there is input signal. It turns itself on and off. The signal time out is 60 seconds (at the moment can be made shorter). Start up time from sleep is 20ms. - 2A solar multi-chemistry battery charger with MPPT. Optimized specifically for CGIS/thin film panels and LiFePO4 batteries but can be used with any solar panel or DC voltage source and other battery types at slightly reduced efficiency. - Innovative single RGB LED status monitoring that shows both amp status and battery status in a whole new and intuitive way.
- Programmable (limited at first) DSP for equalization among others things. Built-in clip limiter and several other functions but that is to be fleshed out and can be user added later with little effort. - On board DIP switches to switch between different operating modes. Let's say you have S2010s and PHT407N, then you set the corresponding DIP switch for that and the EQ is automatically set to suit the optimum for that. - Custom made aluminium case with IP66 rating from Hammond Mfg. Actually I could go on and on about how many considerations and completely new never-seen-before solutions we, or rather the designer Gary Marsh, have crammed into this single 80x100mm PCB. My own involvement is limited to help in laying out the principle features and adding some touches here and there. Edited by Saturnus - 08 May 2014 at 10:46pm |
bitSmasher ![]() Old Croc ![]() ![]() Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2289 |
jizzin'it!
If I was in your position I'd buy the MiniAmp to go with MiniDSP and look to upgrade to the cAMP down the road... then use the Mini things for a smaller project |
Saturnus,
Thanks for the information, the new amp / controller sounds great and may be an option depending on how quick I get the speakers and timber put together. If you need a test bed let me know and happy to Beta test it for you? I also like the idea of the minidsp set up as suggested by BitSmasher, I have a few other projects which this could be useful on so will get one to play with anyway. Thanks, Dupe... |
Dupe...
The built-in DSP in the cAMP is the same as in the miniDSP, so it should be possible to use it precisely as a miniDSP as well. There'll be a 4 channel version later btw.
Delivery date for first batch is June 12th I'm told. |
Thats pretty close, I better get some wood bought.
Dupe.... |
Dupe...
Saturnus,
Just getting the timber and cnc sorted and now looking at wood glue, only used pva before from evostik (green bottle), i note in several of your posts you suggest a epoxy based glue. Would something like this be suitable? http://www.bostik.co.uk/diy/product/evo-stik/Resin-W-Weatherproof-Exterior-Wood-Adhesive/5 Thanks, Dupe... |
Dupe...
Updated first post and added links to suppliers etc.
Dupe... |
Dupe...
I have been attempting to understand the power requirements today, doing some pretty basic calculations and assuming the following:
Minidsp pulls 0.08A 2 * maxamp20 pull 0.4A at reasonable volume Will be used off grid for 1 week Will be used for 8hrs / day Its summer (in the UK that means 4 hrs max sunshine) I recon I need: Minimum 10W solar panel Minimum 7Ah battery (assumes 50% discharge between getting topped up with sun) Does this sound about right? Dupe... |
Dupe...
The normal advice is that one maxamp (or amp6) match with one 10W thin film panel and one 7.2Ah battery.
Given that you have 2 maxamp's I'd reckon a 15W thin film panel and a 9-10Ah lifepo4 or 2x 7.2Ah SLA would match and actually make the battery life about 2-3 months in the summer if care is taken that it's placed in the Sun every day. That's because a 2-way maxamp where each only have one channel doing bass and the other treble uses far less power than if both channels did full-range. A guesstimate would be that each amp would consume 0.25A at absolute max volume and half that turned down just a notch or two. Edited by Saturnus - 12 May 2014 at 2:31pm |
Saturnus, thanks for the great info, just updated my calculation with the 250mA consumption and agree with your numbers. In theory should run indefinitely if I can get 4 hours of sun a day.
Any advice on the glue, is the one I linked to above the type you suggest on other forums? Dupe... |
Dupe...
lutkeveld ![]() Young Croc ![]() ![]() Joined: 23 September 2013 Location: The Netherlands Status: Offline Points: 517 |
And even if there doesn't appear to be sun, you'll still get some output from the panels.
Page 123 11> |
