Boominator MINI (development thread) |
Post Reply | Page <1 8889909192 102> |
Aterren
Registered User Joined: 14 July 2013 Status: Offline Points: 151 |
Duplicate post...
Edited by Aterren - 14 June 2017 at 2:07pm |
Aterren
Thanks(1)
Hi - the measurements in sketchup are accurate from my memory. 82.4 mm on the spec sheet needs to be included because the speakers are mounted on the inside of the baffle.
Also, there is no need / benefit (in my view) to using 12mm. As specified it is a tank and 12mm ply will make it a good bit heavier. Let me know if you need any dimensions. I have drivers and some case parts in the shop and i can take pictures to show you how it all fits. |
cryzies
New Member Joined: 22 May 2017 Status: Offline Points: 3 |
Oh yes please! I'm thinking about using 18650s, probably 4s3p to get ~15V 15A as per my battery specs. Do you have a amp recommendation? I think I saw some people in this thread wanting more power so I want to hit the max RMS wattage possible which is 2x40watt. |
Aterren
Okay. I'll plan to take photos this weekend. Regarding the amp, I recommend the MaxAmp. It is perfectly adequate for this build and the price is good. I don't think you will want more power. It is a very efficient speaker.
uzip498
Registered User Joined: 31 August 2015 Status: Offline Points: 27 |
Hi if I reduce the size of the electrical compartment to half the size would the sound quality be effected?
I read something about baffle dispersion. I'm building the original ns6 version Edited by uzip498 - 10 September 2017 at 7:52am |
Aterren
Reducing the size of the center box is fine though I'm not sure why you would want to. It won't make the overall size materially smaller and it will give you a much tighter install.
uzip498
Ok thanks
cryzies
For the tweeter, is it supposed to be wired out of phase? |
Aterren
Yes. Out of phase.
uzip498
Hi will the sound quality be affected If I use 9mm mdf instead of birch ply for the ns6 mini? Birch ply in Australia is super expensive
mini-mad
No.
uzip498
Sure/wondom electronics have a 18650 3s 11.1v board with balance, over charge, under charge etc board
https://www.parts-express.com/sure-electronics-aa-ja11113-extension-board-18650-batteries--320-3516 |
