Bose 802C2 Controller Frequency Response |
Post Reply | Page 123 6> |
djyves
Young Croc Joined: 06 April 2009 Location: the Netherlands Status: Offline Points: 564 |
Posted: 06 March 2010 at 8:15pm |
I recently bought a Behringer DCX2496 Ultradrive speaker management system and I wanted to use it with my Bose 802's and HD15's. I needed to know what the normal Bose 802C2 controller's frequency changes were. These are the plots (made with SMAARTlive).
No controller: Fullrange: Bi-Amplified Low: Bi-Amplified High: We used a E-MU Tracker pre|USB soundcard. The soundcard seems to be perfectly linear. Edited by djyves - 11 September 2011 at 6:32pm |
DJkg
Registered User Joined: 12 October 2008 Location: Midwest Status: Offline Points: 133 |
It does more than act like an xover, it also does time delay and some other things. Sorry I don't have more info on this, but i've tried it before with my DRPA. Technically it works, but doesn't sound the greatest.
djyves
Can somebody tell me what it does more,
with smaartlive i can measure timedelay so i will try.
yves |
illuminate
Registered User Joined: 05 March 2009 Location: Kent Status: Offline Points: 162 |
Don’t know about the 802C II but the 802C I’m sure is just a few op-amps to provide massive gain boost around about the frequencies you have discovered. It is also an x-over for adding the 302 “subs” and a good source for noise, distortion and premature amplifier clipping. |
Sound is analogue, get over it!
studio45
Yes the controller attempts to correct for all the shortcomings of the physical box design. RIDICULOUS way to build a soundsystem if you ask me. As you can see the 802 only really responds between 400 and 4000Hz. Outside that range it's mostly EQ you are hearing!
illuminate
That's why to top end sounds scratchy and the bass is boomy and prone to feedback. Can you tell I've worked with these things once too often?
Conanski
Crown had a Bose EQ module(PIP-BEQ) for the old amps , the reference manual shows the correction curves for several speaker models including the 802.. http://www.crownaudio.com/pdf/legacy/k80780.pdf
djyves
thanks for that
Guy Johnson
New Member Joined: 30 December 2009 Location: West Wales Status: Offline Points: 7 |
I disagree. The speakers and controller are a package. The 802s on their own Are Not The System. If nowadays there was an 802 with amp / EQ inside it, no-one would complain. I ran 802s for a while 600w each, they were great. Treated with respect for their design, they put out very good, musical material, whether quiet, or very loud... But with kick-drum and more bass, you need subs and x-over, obviously. The bass feedback problems mentioned are due to the lower bass-response of the 802 compared with a standard '15-and-horn' — coupled with the the omni-directionality of that lower bass. The 802 has its uses, especially with really close-up work, where the 802s wide dispersion and sounding good close-up are needed ... where for instance, a standard '12 (or especially 15) and Horn' design will never sound right. My only complaint about the sound would be the lack of the very highest frequencies, but at least the highs are not hyped and 'horny' sounding.
Edited by Guy Johnson - 14 March 2010 at 4:39pm |
djyves
true, I power them with 380w on a dynacord s1200 and some hd 15s and i think it sounds good, the only problem for me is that the hds dont go verry low
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
Many powered speakers need a DSP to tailor their response, you have good parametric EQ on the Behringer so shouldn't be too difficult to get a nice flat response from the 802's with a bit of experimentation.
Alot of people still like the 802 sound! |
North Staffordshire |
djyves
I like the sound of the 802s, and with a bit eq'ing it sounds quite good it can be done better so i'll keep trying to make it better.
