Bose Panaray MA12/MB4 |
wynnefraser
Registered User Joined: 15 August 2007 Location: Australia Status: Offline Points: 6 |
Posted: 18 September 2007 at 12:52pm |
Does anyone have/know of any plans available for either of the Bose Panaray MA12 or MB4 models?
Disco Stu
Old Croc Joined: 03 March 2005 Location: United Kingdom Status: Offline Points: 2487 |
Theres nothing special about the Panaray
You need one of these http://www.billfitzmaurice.com/SLA.html which you can extend to 12 drivers, or one of these which can be made in a pro version with 8x8" drivers http://www.billfitzmaurice.com/TLAH.html
At the end of the day Bose quotes 300W for its panaray MA12 so each 2.5" driver only needs to be rated at 25W - the key here is either to use lots of low efficiency drivers or less of higher efficiency ones. If you are trying to emulate it you want the highest efficiency figures you can find, or that 300W wont mean anything.
So I would say take that first link and scale it up for 8" drivers and a tweeter array with a properly designed crossover.
Stu
All you need to know is:
Sensitivity + Power Handling - Power Compression = Max Output My acts: www.myspace.com/thebowiexperience www.myspace.com/scheisseelektronisches |
